[Qgis-user] Qgis 2.3 nightly build in Mavericks
Larry Shaffer
larrys at dakotacarto.com
Wed May 28 15:57:48 PDT 2014
Hi Sergio,
Thank you for reporting.
On Wed, May 28, 2014 at 1:20 PM, Sergio Zárate <acac09 at gmail.com> wrote:
> Hello all, I tried to open the nightly build of Qgis 2.3 in MacBookPro
> using OS X 10.9.3 and got the following message of error:
> Process: QGIS_2.3-dev [1348]
> Path: /Applications/QGIS_2.3-dev.app/Contents/MacOS/QGIS_2.3-dev
> Identifier: org.qgis.qgis-dev
> Version: ???
> Code Type: X86-64 (Native)
> Parent Process: launchd [271]
> Responsible: QGIS_2.3-dev [1348]
> User ID: 501
> Date/Time: 2014-05-28 14:16:53.882 -0500
> OS Version: Mac OS X 10.9.3 (13D65)
> Report Version: 11
> Anonymous UUID: 362E5C02-C39F-AF3E-4664-86A62C4FD245
> Sleep/Wake UUID: 916C2639-55E0-45CB-B785-748DD2E48979
> Crashed Thread: 0
> Exception Type: EXC_BREAKPOINT (SIGTRAP)
> Exception Codes: 0x0000000000000002, 0x0000000000000000
> Application Specific Information:
> dyld: launch, loading dependent libraries
> Dyld Error Message:
> Library not loaded: /Library/Frameworks/GDAL.framework/Versions/1.11/GDAL
As this error indicates, you need to update to the latest GDAL 1.11
Complete framework from Kyngchaos.com [0]. Sorry, I finished upgrading the
build server with that framework yesterday, but did not have time to update
the nightly website with this information. Will do so today.
[0] http://www.kyngchaos.com/software/frameworks
Regards,
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
Referenced from:
> Reason: image not found
> Binary Images:
> 0x7fff68c1c000 - 0x7fff68c4f817 dyld (239.4)
> <042C4CED-6FB2-3B1C-948B-CAF2EE3B9F7A> /usr/lib/dyld
> Model: MacBookPro8,1, BootROM MBP81.0047.B27, 2 processors, Intel Core i5,
> 2.3 GHz, 4 GB, SMC 1.68f99
> Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In, 384 MB
> Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80CE,
> 0x4D34373142353737334448302D4348392020
> Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80CE,
> AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xD6),
> Broadcom BCM43xx 1.0 (5.106.98.100.22)
> Bluetooth: Version 4.2.4f1 13674, 3 services, 23 devices, 1 incoming
> serial ports
> Network Service: AirPort, AirPort, en1
> Serial ATA Device: Hitachi HTS545032B9A302, 320.07 GB
> Serial ATA Device: MATSHITADVD-R UJ-898
> USB Device: FaceTime HD Camera (Built-in)
> USB Device: Hub
> USB Device: Apple Internal Keyboard / Trackpad
> USB Device: BRCM2070 Hub
> USB Device: Bluetooth USB Host Controller
> USB Device: Hub
> USB Device: IR Receiver
> Thunderbolt Bus: MacBook Pro, Apple Inc., 22.1
> So, I can not try it!
> Regards
> Sergio Zárate
> Dr. Sergio Zárate Pedroche
> José María Arroyo 228
> Col. 22 de octubre
> Morelia, Michoacán
> C.P. 58341
> México
> Teléfono: (443) 352-5307
> Celular: (443) 438-6212
> http://independent.academia.edu/SergioZ%C3%A1ratePedroche
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140528/f6022a7a/attachment.html>
