[Qgis-user] Qgis 2.3 nightly build in Mavericks
Sergio Zárate acac09 at gmail.com
Wed May 28 12:20:26 PDT 2014
Hello all, I tried to open the nightly build of Qgis 2.3 in MacBookPro
using OS X 10.9.3  and got the following message of error:
Process:         QGIS_2.3-dev [1348]
Path:            /Applications/QGIS_2.3-dev.app/Contents/MacOS/QGIS_2.3-dev
Identifier:      org.qgis.qgis-dev
Version:         ???
Code Type:       X86-64 (Native)
Parent Process:  launchd [271]
Responsible:     QGIS_2.3-dev [1348]
User ID:         501
Date/Time:       2014-05-28 14:16:53.882 -0500
OS Version:      Mac OS X 10.9.3 (13D65)
Report Version:  11
Anonymous UUID:  362E5C02-C39F-AF3E-4664-86A62C4FD245
Sleep/Wake UUID: 916C2639-55E0-45CB-B785-748DD2E48979
Crashed Thread:  0
Exception Type:  EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
  Library not loaded: /Library/Frameworks/GDAL.framework/Versions/1.11/GDAL
  Referenced from:
  Reason: image not found
Binary Images:
    0x7fff68c1c000 -     0x7fff68c4f817  dyld (239.4)
<042C4CED-6FB2-3B1C-948B-CAF2EE3B9F7A> /usr/lib/dyld
Model: MacBookPro8,1, BootROM MBP81.0047.B27, 2 processors, Intel Core i5,
2.3 GHz, 4 GB, SMC 1.68f99
Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In, 384 MB
Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80CE,
0x4D34373142353737334448302D4348392020
Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80CE,
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xD6),
Broadcom BCM43xx 1.0 (5.106.98.100.22)
Bluetooth: Version 4.2.4f1 13674, 3 services, 23 devices, 1 incoming serial
ports
Network Service: AirPort, AirPort, en1
Serial ATA Device: Hitachi HTS545032B9A302, 320.07 GB
Serial ATA Device: MATSHITADVD-R   UJ-898
USB Device: FaceTime HD Camera (Built-in)
USB Device: Hub
USB Device: Apple Internal Keyboard / Trackpad
USB Device: BRCM2070 Hub
USB Device: Bluetooth USB Host Controller
USB Device: Hub
USB Device: IR Receiver
Thunderbolt Bus: MacBook Pro, Apple Inc., 22.1
So, I can not try it!
Regards
Sergio Zárate
Dr. Sergio Zárate Pedroche
José María Arroyo 228
Col. 22 de octubre
Morelia, Michoacán
C.P. 58341
México
Teléfono: (443) 352-5307
Celular: (443)  438-6212
http://independent.academia.edu/SergioZ%C3%A1ratePedroche
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140528/c389b992/attachment.html>
