[Qgis-user] Spatial Join in QGIS 2.2
Andre Joost andre+joost at nurfuerspam.de
Thu May 29 06:37:49 PDT 2014
Am 29.05.2014 14:48, schrieb Micha Silver:
> Otherwise, you'll have to somehow verify the CRS of the district boundaries.
> AFAIK, Egypt uses two geodetic reference system know as "Old Egyptian"  or
> "Egypt 1907" with code 6229. The other is called "New Egyptian" or Egypt 1930,
> having code 4199. Maybe the data will overlay correctly if you declare the layer
> to be in one of these CRS? You do that by opening the layer's property window,
> in the "General" tab. There, in the section on coordinate reference system, is a
> button "Specify". Using this button does *not* change the data at all, it only
> declares that the layer is referenced in the CRS that you specify. If that
> works, and the districts with interview locations overlay correctly, then you
> have probably found the right CRS.
It might also help if you can add the extent of the boundary layer as
reported by properties, metadata tab.
HTH,
André Joost
