[Qgis-user] Install problem on OS X 10.9
Gabriel Sidman
gabrielsidman at gmail.com
Thu May 29 13:25:51 PDT 2014
Hi Larry,
Thanks so much for your tip. I was able to fix the problem by changing
"sys.path.insert" path name from "1.10" to "1.11" in
/Library/Python/2.7/site-packages/gdal-py2.7.pth. As you mentioned, it
looks like it was referencing the earlier 1.10 version.
I couldn't try the fix you suggested since the Raster menu in QGIS before
the fix had only "Raster calculator" as an option, it did not have
GdalTools Settings dialog. The GdalTools Settings dialog now appears after
the fix.
Thanks again for your help,
Gabriel
On Thu, May 29, 2014 at 12:20 PM, Larry Shaffer <larrys at dakotacarto.com>wrote:
> Hi Gabriel,
> On Thu, May 29, 2014 at 10:53 AM, Gabriel Sidman <gabrielsidman at gmail.com>wrote:
>> Hello All,
>> I'm an new QGIS user, and am getting the following error upon opening
>> QGIS 2.2:
>> "Unable to load GdalTools plugin.
>> The required "osgeo [python-gdal]" module is missing.
>> Install it and try again."
> Verify that the following file exists:
> and that its contents are:
> import sys;
> sys.path.insert(0,'/Library/Frameworks/GDAL.framework/Versions/1.11/Python/2.7/site-packages')
> (@William, I just installed latest GDAL and the gdal-py2.7.pth still
> appears to reference version 1.10. On a clean install, this may be causing
> the reported issue here.)
> At the bottom of the Raster menu, open GdalTools Settings dialog, and try
> pasting in these settings:
> * Path to GDAL python modules: /Library/Python/2.7/site-packages
> * Path to the GDAL executables: /Library/Frameworks/GDAL.framework/Programs
> * GDAL Help path: /Library/Frameworks/GDAL.framework/Resources/doc
> Then, relaunch QGIS and see if error persists.
>> QGIS still opens and has some functionality, but I think I'm not getting
>> complete functionality.
>> I'm running OS X 10.9.3 on a Mac Book Pro with 2.4 Ghz Intel Core 2 Duo
>> processor. I've installed GDAL 11.1 Complete, GSL framework v1.16-1,
>> matplotlib 1.3.1-2 (all from http://www.kyngchaos.com), and Python 2.7.6
> Note, only the system Python is supported. Installing Python 2.7.6 will
> not update the Python that QGIS is compiled against (i.e. the system's).
> Any modules/packages should be installed in system Python, which is the
> default for Kyngchaos installers. Also, for Mac OS X 10.9.3, the system
> Python is already at 2.7.5, so upgrading to 2.7.6 will not add much.
> Regards,
> Larry Shaffer
> Dakota Cartography
> Black Hills, South Dakota
>> I see this error has been documented before, but it seems to be related
>> to new releases of OS X, but for me this is the first time I have ever
>> installed QGIS so I don't think that's my issue.
>> Any thoughts on where I am going wrong?
>> Thanks,
>> Gabriel
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140529/9456ced5/attachment.html>
