[Qgis-user] Install problem on OS X 10.9
Larry Shaffer
larrys at dakotacarto.com
Thu May 29 12:20:52 PDT 2014
Hi Gabriel,
On Thu, May 29, 2014 at 10:53 AM, Gabriel Sidman <gabrielsidman at gmail.com>
wrote:
> Hello All,
> I'm an new QGIS user, and am getting the following error upon opening QGIS
> 2.2:
> "Unable to load GdalTools plugin.
> The required "osgeo [python-gdal]" module is missing.
> Install it and try again."
Verify that the following file exists:
/Library/Python/2.7/site-packages/gdal-py2.7.pth
and that its contents are:
import sys;
sys.path.insert(0,'/Library/Frameworks/GDAL.framework/Versions/1.11/Python/2.7/site-packages')
(@William, I just installed latest GDAL and the gdal-py2.7.pth still
appears to reference version 1.10. On a clean install, this may be causing
the reported issue here.)
At the bottom of the Raster menu, open GdalTools Settings dialog, and try
pasting in these settings:
* Path to GDAL python modules: /Library/Python/2.7/site-packages
* Path to the GDAL executables: /Library/Frameworks/GDAL.framework/Programs
* GDAL Help path: /Library/Frameworks/GDAL.framework/Resources/doc
Then, relaunch QGIS and see if error persists.
> QGIS still opens and has some functionality, but I think I'm not getting
> complete functionality.
> I'm running OS X 10.9.3 on a Mac Book Pro with 2.4 Ghz Intel Core 2 Duo
> processor. I've installed GDAL 11.1 Complete, GSL framework v1.16-1,
> matplotlib 1.3.1-2 (all from http://www.kyngchaos.com), and Python 2.7.6
Note, only the system Python is supported. Installing Python 2.7.6 will not
update the Python that QGIS is compiled against (i.e. the system's). Any
modules/packages should be installed in system Python, which is the default
for Kyngchaos installers. Also, for Mac OS X 10.9.3, the system Python is
already at 2.7.5, so upgrading to 2.7.6 will not add much.
Regards,
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
> I see this error has been documented before, but it seems to be related to
> new releases of OS X, but for me this is the first time I have ever
> installed QGIS so I don't think that's my issue.
> Any thoughts on where I am going wrong?
> Thanks,
> Gabriel
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140529/82a77b5e/attachment.html>
