[Qgis-user] Categorised Styling of PostGIS layers
Alexandre Neto senhor.neto at gmail.com
Fri May 30 04:01:11 PDT 2014
Somehow QGIS is not finding any of those 3 values in the features in that
extent. Can you select a few visible (pink) features  and check their
probability
field values?
Are you sure that all you features have valid values in the prob column?
Try build that same stack of symbols using rule-based symbology. And see if
it works.
You can also try save a few features in other format, say a shapefile, open
it and copy the style. See if it works there (I doubt).
Not having access to the data, is quite difficult to understand what can be
wrong, if you can provide a sample data, I can give a look into it.
Alexandre Neto
On Fri, May 30, 2014 at 11:35 AM, McDonaldR <McDonaldR at angus.gov.uk> wrote:
>    Morning all,
> I'm trying to style some flooding probability data.  It's in PostGIS and
> I'm using QGIS master (same issue in 2.0 and 2.2 though).  My polygon layer
> has a probability field with values H, M and L.  If I select a categorised
> style using the probability field I get the expected three values.  And an
> extra one.  And the data is drawn using the style of the extra category -
> in the screenshot the pink lines and not the blues as expected.  If I
> delete the extra category from the classification table then nothing is
> drawn on the canvas.  I have checked the field and there are only three
> unique values in it without nulls or blanks.  The table is properly indexed
> with a primary key and GIST spatial index.
> So, is it a QGIS style engine problem or a PostGIS data problem?  I should
> add that the same data from PostGIS draws perfectly in ArcGIS 10.2.2 and is
> styled as expected.
> Anyone else had similar experiences?
> [If the screenshot is scrubbed by the list then you can see it here:
> http://openphoto.mixedbredie.net/photo/96/view]
> *Ross McDonald *| GIS Data Coordinator | Resources Department, IT
> Division | Angus Council, Angus House, Orchardbank Business Park, Forfar,
> DD8 1AT
> T: *01307 476419* | F: 01307 476401 | E: mcdonaldr at angus.gov.uk | W: *Angus
> Maps <http://www.angus.gov.uk/maps/map_home.cfm>*
> This message is strictly confidential. If you have received this in error,
> please inform the sender and remove it from your system. If received in
> error you may not copy, print, forward or use it or any attachment in any
> way. This message is not capable of creating a legal contract or a binding
> representation and does not represent the views of Angus Council. Emails
> may be monitored for security and network management reasons.  Messages
> containing inappropriate content may be intercepted. Angus Council does not
> accept any liability for any harm that may be caused to the recipient
> system or data on it by this message or any attachment.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140530/3c242b59/attachment.html>
