[Qgis-user] Categorised Styling of PostGIS layers
McDonaldR McDonaldR at angus.gov.uk
Fri May 30 03:35:27 PDT 2014
Morning all,
I'm trying to style some flooding probability data.  It's in PostGIS and I'm using QGIS master (same issue in 2.0 and 2.2 though).  My polygon layer has a probability field with values H, M and L.  If I select a categorised style using the probability field I get the expected three values.  And an extra one.  And the data is drawn using the style of the extra category - in the screenshot the pink lines and not the blues as expected.  If I delete the extra category from the classification table then nothing is drawn on the canvas.  I have checked the field and there are only three unique values in it without nulls or blanks.  The table is properly indexed with a primary key and GIST spatial index.
So, is it a QGIS style engine problem or a PostGIS data problem?  I should add that the same data from PostGIS draws perfectly in ArcGIS 10.2.2 and is styled as expected.
Anyone else had similar experiences?
[If the screenshot is scrubbed by the list then you can see it here: http://openphoto.mixedbredie.net/photo/96/view]
Ross McDonald | GIS Data Coordinator | Resources Department, IT Division | Angus Council, Angus House, Orchardbank Business Park, Forfar, DD8 1AT
T: 01307 476419 | F: 01307 476401 | E: mcdonaldr at angus.gov.uk<mailto:mcdonaldr at angus.gov.uk> | W: Angus Maps<http://www.angus.gov.uk/maps/map_home.cfm>
This message is strictly confidential. If you have received this in error, please inform the sender and remove it from your system. If received in error you may not copy, print, forward or use it or any attachment in any way. This message is not capable of creating a legal contract or a binding representation and does not represent the views of Angus Council. Emails may be monitored for security and network management reasons.  Messages containing inappropriate content may be intercepted. Angus Council does not accept any liability for any harm that may be caused to the recipient system or data on it by this message or any attachment.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140530/ed02af3d/attachment.html>
