[Qgis-user] kmz export sed script
José G Moya Y. josemoya at gmail.com
Tue Sep 2 06:12:06 PDT 2014
Hi!
As I said in a previous message, I use qgis to put together many geographic
information sources prior to downloading the data as kmz to my mobile.
That's the reason I wrote a small script to generate kmz icons from a
qgis-generated kml.
That script is a "sed" script, meaning it has to be processed with the
"sed" utility included in Linux. If you have a Windows version of qgis
bundled with Msys (such as osgeo4win), you could probably execute it from
the msys command line.
Someone could try to adapt it to python, but I don't know how to make
python scripts.
Please note: Lines are long and they could be wrapped when sendind as
email. I will use an empty line (two carriage returns) to mark new line.
SCRIPT 1 ---- Generate icons from "name" field
This script takes a qgis-generated kml file, and adds an icon (called
"Cueva.png") to every feature with a name containing "Cueva" or "Sima",
another icon (called ."Icnitas.png") to every feature with a name
containing "icnita" or "Icnita",
another icon (called "Fosil.png") to every feature with a name like
"Fosil", "Fósil", "fosil" or "fósil", and another icon (called "Mina.png")
to every feature with a name containing "Mina".
The icons should be placed in a folder called "images", and zipped along
with the modified kml file in a file with kmz extension.
The script should be invoked like this:
sed mykmlfile.kml -f kmzfromname.sed > newkmlfile.kml
After that, you should use your preferred zip manager to zip together the
files. I use this:
7z -a -tzip newkmlfile.kmz newkmlfilekml images/*.png
but the syntax would be different if you use a different zip manager.
----kmziconfromname.sed------------------CUT
HERE------------------------------------------
#!/bin/sed
#Replace name tag with Cueva or cueva with icon and name tag
/name>[^>]*[Cc]ueva/{;s/<name>/<icon><href>images\/Cueva.png<\/href><\/icon><name>/;};
#Replace name tag with Sima or sima with icon and name tag
/name>[^>]*[Ss]ima/{;s/<name>/<icon><href>images\/Cueva.png<\/href><\/icon><name>/;};
#Replace name tag with Icnita or icnita with icon and name tag
/name>[^>]*[Ii]cnita/{;s/<name>/<icon><href>images\/Icnitas.png<\/href><\/icon><name>/;}
#Replace name tag with F?sil or f?sil (probably, fosil or fósil) with icon
and name tag
/name>[^>]*[Ff].sil/{;s/<name>/<icon><href>images\/Fosil.png<\/href><\/icon><name>/;}
#Replace name tag with Mina or mina with icon and name tag
/name>[^>]*[Mm]ina/{;s/<name>/<icon><href>images\/Mina.png<\/href><\/icon><name>/;}
#Previous code for icons was a pseudocode. Replace it with the real code.
s!<icon>!<Style><IconStyle><scale>1.0</scale><Icon>!;
s!</icon>!</Icon></IconStyle><LabelStyle><scale>1.0</scale></LabelStyle><LineStyle><width>1,0</width></LineStyle></Style>!
#I don't know why, but replacing folder with document allows oruxmaps put a
name (instead of a date) to this layer.
s!Folder>!Document>!
----kmziconfromname.sed-------END OF
FILE-----------------------------------------------------------
SCRIPT 2 ----- Generate icons from a custom field (not "name")
This is a skeleton script. In the previous sample, I used the name to
detect the class of each feature, but my kml file has a field caled
T006_006_C that stores the actual feature class.
So I could use that field instead.
But, in order to do that, I have to read the field inside the
<ExtendedData> tag and, after that, put a new flag outside that tag.
Doing that with SED is tricky, because SED uses to read one line at a time.
We have to tell it to group the whole <ExtendedData> group in a single line.
Please notice you should adapt this script to your needs, i.e., replace
T006_006_C with the field name you want, add code to replace the <!---icon
--> tags with your preferred icon, and so on.
The usage would be again,
sed mykmlfile.kml -f kmzfromfield.sed > newkmlfile.kml
files. I use this:
---kmziconfromfield.sed----------------------CUT
HERE------------------------------------------------------
#!/usr/bin/sed
#Example: how to make icon from field using SED
#Replace T006_006_C with fieldname
:a
N
#Do not put spaces after the backslash in the next line:
s/\
/ /g
/\/ExtendedData/!ba
s/\(<ExtendedData.*SimpleData
name=.T006_006_C.>\)\([^<]*\)\(.*<\/ExtendedData>\)/\1\2\3<!-- Icon_For:\2
#Step 2: Replace <!-- Icon_For:\2 --> with code for icon
(<Style><IconStyle... etc) (See script 1)
#Now you have to change all categories with their icon
#This is an example on how to change "Icon fror:Modelado K*" to the
"Cueva.png" icon:
s/<!-- Icon for:Modelado [Kk].*-->/<icon>Cueva.png<\/icon>/
#Now we change <Icon> pseudocode with real icon code.
#Last of all, we change the <Folder> tag with the <Document> Tag.
#It gives a name for kml layer in oruxmaps.
--kmziconfromfield.sed----------------------END OF
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140902/9b5a0d39/attachment.html>
