[Qgis-user] Check geometry validity tools
Andreas Neumann
a.neumann at carto.net
Fri Sep 5 00:00:40 PDT 2014
I think that Alessio is trying to select an invalid ring within a
polygon or multipolygon. This is not possible in the table.
You may try to correct the invalid feature with the PlainGeometryEditor
plugin: https://plugins.qgis.org/plugins/plaingeometryeditor/
Here you can manually edit each ring and vertex by manipulating the
coordinates in a text-field.
Hope this helps,
Andreas
Am 05.09.2014 06:55, schrieb Bernhard Ströbl:
> Hi,
> if you cannot select it graphically you should select it in the table
> Bernhard
> Am 05.09.2014 08:48, schrieb Alessio Degioannini:
>> Yes.
>> Il 05/09/2014 08:02, Hakala Oiva (MTT) ha scritto:
>>> Have you enabled editing?
>>> Oiva
>>> Well: now i'm trying to select it for delete it, but it seems
>>> impossible....
>>> Someone can help me?
>>> Best regards.
>>> Alessio
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> __________ Information from ESET Mail Security, version of virus
>> signature database 10369 (20140905) __________
>> The message was checked by ESET Mail Security.
>> http://www.eset.com
> http://www.eset.com
