[Qgis-user] Check geometry validity tools
Bernhard Ströbl bernhard.stroebl at jena.de
Fri Sep 5 00:13:20 PDT 2014
Hi Andreas,
you maybe right. However we do not know :-) . I was under the impression
it is a simple polygon with only one ring with less than 4 points. ring0
is the first (and if it is a plain polygon the only) ring, isn't it?
Bernhard
Am 05.09.2014 09:00, schrieb Andreas Neumann:
> I think that Alessio is trying to select an invalid ring within a
> polygon or multipolygon. This is not possible in the table.
> You may try to correct the invalid feature with the PlainGeometryEditor
> plugin: https://plugins.qgis.org/plugins/plaingeometryeditor/
> Here you can manually edit each ring and vertex by manipulating the
> coordinates in a text-field.
> Hope this helps,
> Andreas
> Am 05.09.2014 06:55, schrieb Bernhard Ströbl:
>> Hi,
>> if you cannot select it graphically you should select it in the table
>> Bernhard
>> Am 05.09.2014 08:48, schrieb Alessio Degioannini:
>>> Yes.
>>> Il 05/09/2014 08:02, Hakala Oiva (MTT) ha scritto:
>>>> Have you enabled editing?
>>>> Oiva
>>>> Well: now i'm trying to select it for delete it, but it seems
>>>> impossible....
>>>> Someone can help me?
>>>> Best regards.
>>>> Alessio
__________ Information from ESET Mail Security, version of virus signature database 10369 (20140905) __________
The message was checked by ESET Mail Security.
http://www.eset.com
