[Qgis-user] Check geometry validity tools
Salvatore Larosa lrssvtml at gmail.com
Fri Sep 5 01:33:03 PDT 2014
Hi Alessio,
On Fri, Sep 5, 2014 at 10:06 AM, Alessio Degioannini
<a.degioannini at proterstudio.com> wrote:
> Hi All,
> as i have written in the first message, the polygon is a ring with less then
> 4 points...
>> You may try to correct the invalid feature with the PlainGeometryEditor
>> plugin: https://plugins.qgis.org/plugins/plaingeometryeditor/
>> Here you can manually edit each ring and vertex by manipulating the
>> coordinates in a text-field.
> The polygon is not selectable, also in PlainGeometryEditor.
please, if it is not a sensitive data would be useful if you could
share a sample of the dataset.
my guessing here is that you should run the make valid script (lwgeom
algotithm by processing plugin) before.
Best Regards,
-SL
Salvatore Larosa
linkedIn: http://linkedin.com/in/larosasalvatore
twitter: @lrssvt
skype: s.larosa
IRC: lrssvt on freenode
