[Qgis-user] superscript in a filed name
Andreas Neumann
a.neumann at carto.net
Tue Sep 9 09:52:17 PDT 2014
Not in the attribute table. But in the display field or in the print
composer you can use HTML. By using HTML markup you can then use
sub/superscript.
This does not work in the field names of an attribute table.
Andreas
Am 09.09.2014 12:22, schrieb Edita Laurinaviciute:
> Hi All,
> Is it possible to have a superscript in an Alias renaming attribute
> table's field name?
> I need to dispaly a table where a field name should be m^3 /s instead
> of m3/s.
> Many Thanks.
> Edita
> Email Disclaimer: http://www.opw.ie/en/disclaimer/
> Qgis-user mailing list
