[Qgis-user] superscript in a filed name
Edita Laurinaviciute edita.laurinaviciute at opw.ie
Wed Sep 10 03:11:47 PDT 2014
Hi Andreas,
Thanks for the answer.
But I can't figure out what do you mean " in the display field or in the
print composer"?
HTML works on label feature. But in the attribute table I can't get it
working. By the way I am using QGIS 2.1.
Thanks,
Edita
On 09/09/2014 17:52, Andreas Neumann wrote:
> Hi,
> Not in the attribute table. But in the display field or in the print
> composer you can use HTML. By using HTML markup you can then use
> sub/superscript.
> This does not work in the field names of an attribute table.
> Andreas
> Am 09.09.2014 12:22, schrieb Edita Laurinaviciute:
>> Hi All,
>> Is it possible to have a superscript in an Alias renaming attribute
>> table's field name?
>> I need to dispaly a table where a field name should be  m^3 /s instead
>> of m3/s.
>> Many Thanks.
>> Edita
>> Email Disclaimer: http://www.opw.ie/en/disclaimer/
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
