[Qgis-user] How to import a Google map
Carlos Cerdán
sig.upagu at gmail.com
Wed Sep 10 07:08:46 PDT 2014
In Google Earth select the layer (place), right click and "save place as..."
Select type file KML. Default is KMZ.
Open in QGIS as a vector layer (select filter to "KML")
2014-09-10 8:56 GMT-05:00 labiancamarilena at libero.it <
labiancamarilena at libero.it>:
> Hello,
> today I saw a tutorial where the author sayd that it's better to save the
> map as kml file, but when I try to save the map (edited by my colleague in
> google maps) I don't see any button o comand.
> ----Messaggio originale----
> Da: sig.upagu at gmail.com
> Data: 10/09/2014 14.40
> A: "labiancamarilena at libero.it"<labiancamarilena at libero.it>
> Cc: "qgis-user at lists.osgeo.org"<qgis-user at lists.osgeo.org>
> Ogg: Re: [Qgis-user] How to import a Google map
> Hi Marilena:
> In Google Earth, you must save your "place" as kml file.
> In QGIS you can open directly this KML. If you want edit it, then save
> this KML file as a new SHP file.
> Good luck
> Carlos Cerdán
> 2014-09-10 5:30 GMT-05:00 labiancamarilena at libero.it <
>> Hi,
>> my colleague has done a map indicating some points
>> using google maps.
>> I would like to import into Qgis.
>> How can I do? Is there a plugin?
>> thanks
>> Marilena
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140910/551b6762/attachment.html>
