[Qgis-user] I: CONVERT CLOSED LWPOLYLINES
pedrali.carlo pedrali.carlo at tiscali.it
Fri Sep 12 05:51:06 PDT 2014
  _____
Da: qgis-user-bounces at lists.osgeo.org
[mailto:qgis-user-bounces at lists.osgeo.org] Per conto di Carlo Pedrali
Inviato: martedì 9 settembre 2014 15.35
A: qgis-user at lists.osgeo.org
Oggetto: [Qgis-user] CONVERT CLOSED LWPOLYLINES
I’AM NEW ENTRY IN QGIS.
I HAVE A DRAW IN CAD
WITH DIFFERENT LAYERS
THAT I MUST CONVERT IN SHP
OF LINES; POINTS
AND POLIGON AREAS.
I TRY WITH GRASS FOR
CONVERT DIFFERENT DXF FILES
OF EVERY LAYER CAD.
BUT I DON’T ABLE CONVERT
THE CLOSED POLYLINES IN
POLYGON AREAS.
I USE THE “V.TYPE.LB” IN GRASS TOOLS
BUT I DON’T’ CAN TO INPUT THE VETTORIAL FILE
DXF CONVERTED IN THE WINDOW  “NAME OF
VETTORIAL IN INPUT”. WHY?
THE SAME EVENT VERIFY IF I TRY THE CONVERT
THE POLYLINES IN LINES.
THANKS, FOR HOPE
CARLO
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140912/79e24b27/attachment.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140912/79e24b27/attachment.txt>
