[Qgis-user] exporting text to Illustrator?
Alex Mandel tech_dev at wildintellect.com
Fri Sep 19 11:26:25 PDT 2014
On 09/18/2014 11:24 PM, Alex Mandel wrote:
> On 09/18/2014 10:40 PM, Innisfree McKinnon wrote:
>> Hello,
>> I'm working on a map with a large number of labeled streets. I exported the
>> map to Illustrator by saving as SVG. But the exported labels do not seem to
>> have arrived as editable text. I have searched around on the web for a
>> solution, but haven't found a solution. I saw this was a bug with the new
>> labeling engine, but has it been solved? If not I will need to re-enter
>> every label.
>> thanks,
>> Innisfree
> The ticket in question is http://hub.qgis.org/issues/3975
> And previous attempt at a fix
> https://github.com/qgis/QGIS/pull/1096#issuecomment-39040544
> and some more comments on a merge request.
> https://github.com/qgis/QGIS/pull/1286
> So yes looks the like bug is still open, but at the same time it looks
> like the code is in, can't tell if 2.4 or if you need a nightly build.
> It is also unclear if there is a dialog to set the export format or if
> you have manually tweak the qgs project file.
> Larry is the one who will know.
> Thanks,
> Alex
Reading over it, I'm pretty sure the fix is in the Master version (aka
development builds).
Looks like you can try it easily on Mac with no install (since you
already have the frameworks)
http://qgis.dakotacarto.com/
Thanks,
Alex
