[Qgis-user] Maprenderer Deprecated: what does this mean?
Andreas Neumann
a.neumann at carto.net
Mon Sep 22 04:03:07 PDT 2014
This means that the author of the Plugin RectovalDigit needs to upgrade
the code because an older API method he used is now deprecated. There is
a new method available to take over the same functionality.
See http://qgis.org/api/classQgsMapCanvas.html
and
http://qgis.org/api/classQgsMapCanvas.html#a85b189f9b739294c88bc77587e1fb9a0
If you disable the aforementioned plugin, or if the plugin author
provides an improved version, the message should go away.
Andreas
Am 22.09.2014 10:34, schrieb Joris HINTJENS:
> HI
> I get this warning every time I move a map. (see below)
> What does this mean in Human language?
> Should I worry/take actions?
> Thanks
> warning:C:/Users/jh/.qgis2/python/plugins\rectovalDigit\rectovaldigit.py:233:
> DeprecationWarning: QgsMapCanvas.mapRenderer() is deprecated
> renderer = mc.mapRenderer()
> traceback: File
> "C:/Users/jh/.qgis2/python/plugins\rectovalDigit\rectovaldigittools.py",
> line 399, in canvasReleaseEvent
> self.emit(SIGNAL("rbFinished(PyQt_PyObject)"), geom)
> Joris *HINTJENS*
> Qgis-user mailing list
