[Qgis-user] A problem to connect external ODBC host - any database Mysql, MSSQL, Sybase, Filemaker - it only works in localhost
Lorenzo Moretti
lorenzo.moretti at enea.it
Mon Sep 22 06:42:23 PDT 2014
Hi all
QGIS 2.x has GDAL driver inside and it's possible to connect ODBC source.
This is very useful to connect big external data with your local map.
ODBC driver in GDAL 1.10 or 1.11 works with localhost database and external IP host with any databases. I've tested with Mysql, MSSQL, Filemaker Pro.
QGIS 2.x works only with localhost ODBC source. If you enter an external IP host you have always connection error.
GDAL driver works but QGIS (2.x or 1.x) has an error only for external IP.
ODBC is useful for acquiring big external data.
Is it possible to fix this error inside QGIS 2.x ?
Thanks in advance
Lorenzo Moretti
ENEA UTSISM
Unità Tecnica di Ingegneria Sismica
Technical Unit of Seismic Engineering
ENEA - Agenzia nazionale per le nuove tecnologie,
l'energia e lo sviluppo economico sostenibile
ENEA - The Italian Agency for new technologies,
energy and sustainable economic development
http://www.enea.it
via Martiri di Monte Sole, 4
40129 BOLOGNA - ITALY
tel: +39-051-6098086
fax: +39-051-6098544
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140922/dbef54f8/attachment.html>
