[Qgis-user] Finding Points which do not overlay
Damien Stephens
Damien.Stephens at sandfire.com.au
Mon Sep 22 17:12:08 PDT 2014
My suggestion would be to create a buffer of 3m around your original points. (vector/geoprocessing/buffer
That creates a new vector table. (vector Buffer)
Load the new vector table is it isn’t already
Then do a spatial query select source features from: new points table
Where the feature: within
Reference features of : vector buiffer
Open the attributers table of you new points table then click on the invert selection button (yellow triangle with two green arrows in a circle.)
Should give you all the points that have moved, assuming that your original points were more than 3 metres apart.
Then if you want them as a separate table, just edit/copy
Then edit/paste features as
Cheers
Damien
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Carlos Cerdán
Sent: Tuesday, 23 September 2014 3:44 AM
To: henrik_f
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Finding Points which do not overlay
Hi Henrik:
If you still don't solve your issue, perhaps you can try this:
1. If you don't have it, Calculate X and Y coords. for your two layers
2. Make a table union, in layer properties
3. Create two new fields for calculate difference of coordinates (Xi - Xj) and (Yi - Yj)
4. Calculate the absolute distance between points in a new field, with the two previous.
5. This last field is your criterion about absolute difference between points.
Good luck
Carlos Cerdán
2014-09-19 9:35 GMT-05:00 henrik_f <henrik.feltens at gmx.de<mailto:henrik.feltens at gmx.de>>:
Hey,
So I will get right to the problem I have.
I have two different Layers with the same content from different times. Now
I want to know which points changed their location and which have been added
or deleted so I just wanted to find the points which do not overlay by using
Vector -> Geoprocessing Tools -> Difference
(I wasnt sure if the one I was looking for was Symetrical Differnce so I
tried both)
I then realzied that not a single point was overlaying due to the fact that
the points that should have the same location were all seperated by about 3
meters.
Pictures: In the first picture you see a red point. Out of these kind of
points I want to make a new layer. The second picture is a zoomed in version
of the area highlighted in the first one.
<http://osgeo-org.1560.x6.nabble.com/file/n5162929/Pic1.png>
<http://osgeo-org.1560.x6.nabble.com/file/n5162929/Pic2.png>
Here is my question: How do I find the points which are not in distance of
3m to each other?
I made some attempts with buffers and the difference tool again but non
worked.
Does anyone have an idea?
Greetings
Henrik
View this message in context: http://osgeo-org.1560.x6.nabble.com/Finding-Points-which-do-not-overlay-tp5162929.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140923/0228b1cc/attachment.html>
