[Qgis-user] Layer doesn't appears during atlas generation
Andreas Neumann
a.neumann at carto.net
Wed Sep 24 04:13:41 PDT 2014
This can have a number of reasons:
At least two come to my mind:
1. The checkbox "Hidden coverage layer" is active
2. A rendering rule does not apply in atlas mode, because you reference
a map that has a different id than your atlas map
Did you check if the above 2 points do not apply?
Andreas
Am 24.09.2014 10:27, schrieb Luis Miguel Royo PĂ©rez:
> Hi everyone,
> in the print compositor i have two maps, one in detail which changes
> with atlas, and another general and static which should show the grid
> used for the atlas generation. This second one it doesn't appear in the
> final map.
> Is this a bug or related?
> Thank you!
> Qgis-user mailing list
