[Qgis-user] Layer doesn't appears during atlas generation
Luis Miguel Royo Pérez luis.miguel.royo at gmail.com
Wed Sep 24 04:38:56 PDT 2014
Was the first point. I miss it!
Thanks a lot!! Sorry for the inconvenience! :)
El 24/09/14 a las #4, Andreas Neumann escribió:
> Hi,
> This can have a number of reasons:
> At least two come to my mind:
> 1. The checkbox "Hidden coverage layer" is active
> 2. A rendering rule does not apply in atlas mode, because you reference
> a map that has a different id than your atlas map
> Did you check if the above 2 points do not apply?
> Andreas
> Am 24.09.2014 10:27, schrieb Luis Miguel Royo Pérez:
>> Hi everyone,
>> in the print compositor i have two maps, one in detail which changes
>> with atlas, and another general and static which should show the grid
>> used for the atlas generation. This second one it doesn't appear in the
>> final map.
>> Is this a bug or related?
>> Thank you!
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
