[Qgis-user] Non Earth projection
Alex Mandel
tech_dev at wildintellect.com
Tue Sep 30 09:06:40 PDT 2014
On 09/30/2014 03:10 AM, Priscilla Maisie wrote:
> Hi,
> I need to work in a non earth map projection system. Can't locate the
> option on qgis. Is there a way I can create this?
> Regards,
> Priscilla
Yes you can create your own projection in Settings->Custom CRS.
You'll need to create your own proj4 compatible string. Comparing a few
similar projections should help you figure out what you need.
Note in recent versions of QGIS if you look in the Projection on the Fly
dialog, there are several Mars projections and Coordinate systems.
Need more help, please provide more information about the planet
size/shape and type of projection.
Other references, http://epsg.io and http://spatialreference.org
Thanks,
Alex
