[Qgis-user] OpenLayers plugin not consistently loading all tiles
Mike Flannigan mikeflan at att.net
Tue Sep 30 18:17:37 PDT 2014
Regarding number 3 below, you are absolutely right.
It happens for me too on QGIS 2.4 on a Win 7 64bit.
All I can tell you is that it does not happen with
Google Hybrid.  Maybe that will work for you.
Mike
On 9/29/2014 6:09 AM, qgis-user-request at lists.osgeo.org wrote:
> I'm seeing a consistent issue with the Openlayers plugin.
> I have installed the prebuilt binary of QGIS 2.4 on a Win 7 64bit
> platform. Added plugins are Qgis2threejs, viewshed analysis and
> MultiQML. CRS is OSGB:1936.
> I'm using the Openlayers plugin to fetch Bing aerial with labels as a
> base map.   I experience incomplete loading of tiles in three situations.
> (1) When loading the Bing layer, not all tiles are loaded. Hitting F5
> (refresh) will fix it so this is not too much of a problem
> (2) There is a consistent unloaded column of tiles the the RHS. I can't
> find a workaround for this. All I can do is clip it.
> (3) The biggest issue is when using Print Composer to render to a jpg
> file. In this case perhaps only 0-25% of tiles are loaded. No
> workaround. See pc.jpg atttached.
> I am a new user so I have much to learn so I'm not sure if this is a bug
> or a user issue. Does anyone else see the same problems and have any
> suggestions that I might try?
> Thanks,
> NB
