[Qgis-user] QGIS - Graphic Design Workflow
Ezra Boyd ezgis76 at gmail.com
Tue Dec 1 14:06:22 PST 2015
Hello,
I am working with a group to map industrial accidents on periodic basis.
The head of the NGO wants to have a graphic designer to polish the maps
that QGIS produces.  I know that the standard workflow is the export to a
pdf or svg in QGIS and then use Inkscape or Illustrator to improve the
appearance of the map.  However, since they want to produce this on a
bi-weekly basis, this adds a step that would be not be ideal setup over the
long run.
Does anyone know if this workflow can be reversed so that the graphic
designer than produce a polished template that I can then import and use in
QGIS?
Thank you very much,
Ezra
Ezra Boyd, PhD
DisasterMap.net, LLC <http://DisasterMap.net>
ezgis <ezgis76 at gmail.com>76 at gmail.com <ezgis76 at gmail.com>
(504)533-4447
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151201/a4addfb9/attachment.html>
