[Qgis-user] QGIS - Graphic Design Workflow
Andreas Neumann
a.neumann at carto.net
Wed Dec 2 00:11:46 PST 2015
Hi Ezra,
You can bring in SVG files from Illustrator or Inkscape for more complex
graphics from your designers. Everything else can be easily done in QGIS
these days - if you use a recent version of QGIS (e.g. 2.10 or 2.12).
The QGIS print composer is meanwhile more powerful than people think. I
think there are only very rare cases where you really have to export the
final maps into a graphics software like Illustrator or Inkscape.
If you find any shortcomings in the print composer or missing features,
please let us know.
Andreas
On 01.12.2015 23:06, Ezra Boyd wrote:
> Hello,
> I am working with a group to map industrial accidents on periodic
> basis. The head of the NGO wants to have a graphic designer to polish
> the maps that QGIS produces. I know that the standard workflow is the
> export to a pdf or svg in QGIS and then use Inkscape or Illustrator to
> improve the appearance of the map. However, since they want to
> produce this on a bi-weekly basis, this adds a step that would be not
> be ideal setup over the long run.
> Does anyone know if this workflow can be reversed so that the graphic
> designer than produce a polished template that I can then import and
> use in QGIS?
> Thank you very much,
> Ezra
> Ezra Boyd, PhD
> DisasterMap.net, LLC <http://DisasterMap.net>
> ezgis <mailto:ezgis76 at gmail.com>76 at gmail.com <mailto:ezgis76 at gmail.com>
> (504)533-4447
> *_
> _*
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151202/7f5b9aaf/attachment.html>
