[Qgis-user] wrong scale printing with qgis web client
Bernhard Ströbl bernhard.stroebl at jena.de
Wed Dec 2 03:20:20 PST 2015
Hi Enrico,
the scalebar on the pdf obviously does not fit the numerical scale.
Questions:
1) First we have to determine, if a) the numerical scale is wrong but
the scalebar is correct or b) vice versa. What happens if you print out
the same Layout in the same project from QGIS desktop in scale 1:1000?
Does the scalebar fit the numerical scale? Is the displayed map extent
the same?
2) What projection(s) do you use?
3) Which version of QGIS server are you running?
Bernhard
Am 02.12.2015 um 11:54 schrieb Enrico Ferreguti:
> Hi,
> I'm getting prints with wrong scale from qgis web client.
> Apparently everything is fine, I select the layout, the scale from the
> select box, I place the bounding box in the map and then I print. The
> layout contains a numeric scalebar that correclty reports the selected
> scale but if I manually measure on paper the printed image appears that
> the map has a wrong scale by a 1.43x factor
> I verified the behaviour with different projects and projections on
> various servers.
> Should I open a ticket or Am I doing something wrong?
> Attached there is a print with wrong graphical and numeric scalebars.
> The location is the following:
> http://www.openstreetmap.org/#map=19/45.3963826129/11.8795777003
> Regards.
> Enrico Ferreguti
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
__________ Information from ESET Mail Security, version of virus signature database 12658 (20151202) __________
The message was checked by ESET Mail Security.
http://www.eset.com
