[Qgis-user] Form not opening on osx
emmexx emmexx at tiscalinet.it
Thu Dec 3 03:01:34 PST 2015
Il 12/02/2015 10:13 AM, emmexx scrisse:
> When I open the layer properties - Fields and click on Edit widget of my
> widget nothing happens in the debugger. The widget configuration window
> (Edit widget properties) opens but the only parameter field is missing.
> If I select (on the left) another type of field (check box, text
> edit...) their respective configuration parameters are displayed in the
> window. But if I select again my widget, the configuration parameters of
> the last selected widget stays on the window.
As a test I created a new widget based on Matthias tutorial:
http://blog.vitu.ch/10142013-1847/write-your-own-qgis-form-elements
First I created the files for a new plugin using the plugin builder.
In the test_widget.py file I added the tutorial code (the one using re).
In the method initGui of the plugin I added the 2 lines to register the
widget.
When I try to select my test widget in the field configuration of a
layer nothing happens. Only Editable field and Label on top controls are
displayed in the widget configuration.
Same behaviour as my widget.
Is it possible to download a plugin with a custom widget in order to
check if I'm doing something wrong in the plugin setup file?
thank you
	maxx
