[Qgis-user] Form not opening on osx
Alexander Bruy
alexander.bruy at gmail.com
Fri Dec 18 10:34:44 PST 2015
Hi maxx,
I also try to get custom widgets to work. In my test plugin I was
managed to create widget, but editing functionality does not work.
Attached my code, hope you will find it useful.
2015-12-03 13:01 GMT+02:00 emmexx <emmexx at tiscalinet.it>:
> Il 12/02/2015 10:13 AM, emmexx scrisse:
>> When I open the layer properties - Fields and click on Edit widget of my
>> widget nothing happens in the debugger. The widget configuration window
>> (Edit widget properties) opens but the only parameter field is missing.
>> If I select (on the left) another type of field (check box, text
>> edit...) their respective configuration parameters are displayed in the
>> window. But if I select again my widget, the configuration parameters of
>> the last selected widget stays on the window.
> As a test I created a new widget based on Matthias tutorial:
> http://blog.vitu.ch/10142013-1847/write-your-own-qgis-form-elements
> First I created the files for a new plugin using the plugin builder.
> In the test_widget.py file I added the tutorial code (the one using re).
> In the method initGui of the plugin I added the 2 lines to register the
> widget.
> When I try to select my test widget in the field configuration of a layer
> nothing happens. Only Editable field and Label on top controls are displayed
> in the widget configuration.
> Same behaviour as my widget.
> Is it possible to download a plugin with a custom widget in order to check
> if I'm doing something wrong in the plugin setup file?
> thank you
> maxx
Alexander Bruy
Type: application/x-bzip2
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151218/93d0d53a/attachment.bin>
