[Qgis-user] more postgis and osm data help needed
Thomas Endres
endres.thomas at gmail.com
Fri Dec 4 11:23:21 PST 2015
Hi Everyone,
While all of my shapefiles have been imported into PostGIS and work great
in QGIS, I am struggling to do the same with OSM data.
I've tried some suggestions from this list to no avail - hoping for some
fresh eyes.
Using the following with QGIS 2.12.1, Postgres 9.4.5, and PostGIS 2.2 on an
ubuntu instance.
Postgres is running locally at our office and is a beast of a machine - no
issues with hardware.
osm2pgsql --create --slim --cache 14000 --number-processes 4
--multi-geometry --hstore -d osm --flat-nodes /usr/local/osm/flat_nodes.bin
--style /usr/local/osm/default.style /tmp/north-america-latest.osm.pbf
After the data is loaded, primary keys and indexes are generated and a full
vaccuumm is performed.
Start with an empty project, disable 'Render',
add planet_osm_lines to the project and create a rule:
"railway" = 'rail'
enable 'Render'
results in progress bar ina an endlessly active state with nothing ever
drawn.
How does one go about a diagnosis from this point?
A few quesions:
- There is no SRID specifically called on the import - is it defaulting to
900913 succesfully or should it be called as I see this error in QGIS:
2015-12-02T11:53:20 1 Feature type or srid for way of
"public"."planet_osm_polygon" could not be determined or was not requested.
Is this error fixable?
- Might the use of --slim and --flat-nodes switches be causing issues?
- Is it possible to see what processes are responsible for the
ProgressBar's active state?
On several occassions I have been stuck with an active ProgressBar with
nothing apparent going on.
Cancelling out leaves me with a dark screen and a force quit. Joy.
Also seeing the following in QGIS Messages:
2015-12-02T11:31:49 1 NOTICE: WARNING: there is no transaction in progress
2015-12-02T11:32:00 1 NOTICE: row number 0 is out of range 0..-1
2015-12-02T11:33:22 1 NOTICE: row number 0 is out of range 0..-1
2015-12-02T11:34:32 1 NOTICE: WARNING: there is no transaction in progress
2015-12-02T11:34:51 1 NOTICE: WARNING: there is no transaction in progress
and
Simplify transform error caught: forward transform of
(nan, -1.570796)
PROJ.4: +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0
+y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs +to +proj=merc +a=6378137
+b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m
Error: tolerance condition error
Any thoughts welcome.
-tom
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151204/a5f9e6d0/attachment.html>
