[Qgis-user] Issue opening Esri File Geodatabase Multi_Line Z
Nyall Dawson nyall.dawson at gmail.com
Tue Dec 8 11:59:43 PST 2015
On 9 Dec 2015 6:05 AM, "Veinot, Tyler" <tveinot at charlottetown.ca> wrote:
> Windows 7 64bit Pro 6.1 Build 7601, QGIS 2.12.1, Esri Arc Desktop 10.3
> Hello;
> I have a file geodatabase which contains my data and out of the blue when
I open a specific polyline Z feature Q crashes. The feature opens in Arc
Desktop, I ran my check and rebuild geometry with no success. It will open
when I export it to a shape file Z enabled. It is a 2.5D feature class,
2954 PEI Double Stereographic NAD83 CSRS98 using CGVD2013. I also cleared
the CS and spatial references and still no luck, was hoping someone out
there might have run into this before and can help me out. It also crashes
QGIS 2.8 and 2.xx (an older version a college was running not sure the
version). I even tried exporting to shape, deleting the feature class and
reimporting the shape to feature class, still no luck.
Sounds like it's an issue with the OGR geodatabase driver. If you try to
convert it on the command line to a shapefile using OGR2OGR, do you also
see a crash?
Nyall
> Any suggestions?
> Tyler
> Please consider the environment before printing this e-mail!
> ________________________________
> This e-mail and any files transmitted with it are confidential and
intended solely for the use of the individual or entity to whom they are
addressed. Any views or opinions presented are solely those of the author
and do not necessarily represent those of the City of Charlottetown. If you
are not the intended recipient, be advised that you have received this
e-mail in error and that any use, dissemination, forwarding, printing or
copying of this e-mail is strictly prohibited. Please notify the sender
immediately by e-mail if you have received this e-mail by mistake and
delete this e-mail from your system.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151209/6623d9c5/attachment.html>
