[Qgis-user] Setting Data-Defined Fill Colors in One Fell Swoop (QGIS 2.12.1, Win 7 64 bit)
Andreas Neumann a.neumann at carto.net
Wed Dec 16 00:10:28 PST 2015
Hi Terry,
You can use data-defined symbology in any renderer. It isn't limited to
rule-based renderers.
Data-defined means either:
a) you have a column with the necessary values for the style (e.g. a
column with RGBA values for your fill colors)
b) you set an expression (calculation) with logic that generates your
style on the fly. The result of the expression must be a compatible
value (e.g. an RGBA color). Your expression may also contain logic with
CASE WHEN END or you can merge several attribute values into a common color.
Unfortunately, as you discovered, the legend will only contain the
default styles you chose and does not reflect any combination the can
come up with your expression rules. Apparently, it is not easy to create
such a legend, when data-defined styling is involved. It could also be a
performance problem if you have big data sets and QGIS would have to
analyze your data every time you print something in print composer.
Note also - that there are two different legends. The one in the main
application (layer tree) and the other in the print composer on print
layouts.
If you have an idea how to solve this issue, please let us know. It also
bothers me. Maybe a semi-automated way that allows the map author to
assign common occurences of style combinations.
Andreas
On 16.12.2015 08:58, Terry Morse wrote:
> I wanted to set the colors for a polygon vector layer from an attribute field I defined. So I set the layer style to rule-based and discovered that I had to define a rule for each of the 33 attribute values individually. Additionally, although the colors display properly on the map, the rules didn't carry over to the legend symbols. It appears that data-defining is not available for legend symbols and that I will have to set each of them manually.
> Is there a way to create a single rule and data definition that will apply to all the values in one fell swoop, and will also be reflected in the legend? If not, I would like to suggest this as a feature for a new version of QGIS.
> Thank you,
> Terry Morse
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
