[Qgis-user] Something strange with the memory
DelazJ
delazj at gmail.com
Sun Dec 20 03:56:19 PST 2015
Hi
Laurence, I think you faced some known issues.
About memory leak, it seems QGIS is not the responsible but some plugins
related to digitizing [0][1]. Do you have any of them? If so, disable them
and try to work again. I'm not sure you need to reinstall QGIS nor Windows,
I had this kind of problem with some of the last QGIS versions. Just stay
aware about plugin uses.
Is the issue with mixed attributes the same as reported here [2]? Have you
changed the structure of your layer? With Table Manager plugin, Processing
Refactor Fields or Attribute table/Field Calculator? It may be interesting
to add your experience to the bug report so that dev can narrow this issue.
[0] https://hub.qgis.org/issues/13869
[1] https://hub.qgis.org/issues/13794
[2] https://hub.qgis.org/issues/13298
Regards,
DelazJ
2015-12-19 6:26 GMT+01:00 Nicolas Cadieux <nicolas.cadieux at archeotec.ca>:
> Hi Laurence
> "Unfortunately, after 4 or 5 times I saved files, qGIS starts 'not
> responding', a lag which the first times is some seconds and becomes
> several minutes and then I have to reboot the computer.".
> I have had this problem in the past with other versions of QGIS. For me,
> I would wait then save and close the project and QGIS and start it over
> again. I did not need to reboot. Looks like a memory leak of some kind.
> I haven't had this problem in some time. Have you tried to completely
> reinstall QGIS and all the plugins? I would do that as many things are
> all going wrong at once. I would destroy all registry keys and all .QGIS
> folders in your user profiles (you can back them up).
> If is't still a problem, go with 2.8 which is more stable. I would also
> look at the state if your Windows also. My guess is that the install is a
> few years old. Windows 7 is better then xp but it slow down after a few
> years and gets all messed up. It could help to reinstall Windows if all
> else fails especially if you are having problems updating Windows 7. That
> is usually then beginning of the end with Windows 7.... :(
> Nicolas Cadieux M.Sc.
> Les Entreprises Archéotec inc.
> 8548, rue Saint-Denis Montréal H2P 2H2
> Téléphone: 514.381.5112 Fax: 514.381.4995
> www.archeotec.ca
> On Dec 18, 2015 21:14, "Laurence Béchet [via OSGeo.org] " <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5242044&i=0>> wrote:
> Hi,
> I've have experienced recently on several occasions a strange behavior of
> qGIS with what I think, memory. I cannot reproduce with a basic example, I
> need my whole project to make it happen.
> I'm working for a conservation project and I've got a set of shapefiles
> with streams, tracks, contours .... and our traps and baitstations (we do
> pest control). I'm currently trying to make maps of bird census for our end
> of year reports.
> Most of the data I get are from GPS, which is easy to handle (either the
> gpx file of by importing a csv file). But I also have to create shapefiles
> (points and polygons) to place bird sightings and draw territories. These
> files don't have any columns for GPS coordinates, as I draw the points or
> polygons using field markers (sighting next to a trap or near a track). So
> I create the shapefile, fill it in with a few data and save it, then fill
> it in with more data.
> Everything goes well until the moment I save the shapefile again. It is
> saved but the points or polygons get all mixed. They are at the good place
> but not for the bird they were supposed to represent!
> I spent 2 days trying to understand what was possibly wrong and the only
> way I managed to make it work was to create a new shapefile each time I
> saved new data.
> Is there a way to trace what is happening? Nothing appears in the log
> messages nor in the windows event logs, it seems.
> I'm using windows 7 pro 64bits , qGIS 2.12.1-Lyon code revision 16760fd.
> Same problem with 2.13.0
> I'm not connected to any databases, just working locally, no WMS
> connection and qGIS takes already ages to load the project (~3min). It
> never happened to me with the old versions like Dufour.
> Any hints about what to check, look for would be much appreciated ...
> Cheers
> Laurence
> Qgis-user mailing list
> <a
> href="/user/SendEmail.jtp?type=node&node=5242035&i=0">[hidden
> email]
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/Something-strange-with-the-memory-tp5242035.html
> To start a new topic under Quantum GIS - User, email
> ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, <a href="
> http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==">click
> here.
> <a href="
> http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id&%2361;instant_html%21nabble%3Aemail.naml&base&%2361;nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs&%2361;notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>"
> style="font:9px serif">NAML
> View this message in context: Re: Something strange with the memory
> <http://osgeo-org.1560.x6.nabble.com/Something-strange-with-the-memory-tp5242035p5242044.html>
> Sent from the Quantum GIS - User mailing list archive
> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at
> Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151220/422c97eb/attachment.html>
