[Qgis-user] OSGeo4W-packages for GRASS 7 only in QGIS
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Mon Dec 21 10:50:01 PST 2015
Hi Jürgen,
Thanks for your reply.
I am aware that the GRASS plugin is not available in 64bit (I am following yours and Martin Landa`s activity in this regards and looking forward to the 7.0.3 release, hopefully in Januar).
I was referring to OSGeo4W 32bit (sorry for not being specific right away). In 32bit the GRASS 6 plugin works fine, the GRASS 7 plugin hower, is unfortunately not available. As mentioned the package(s) seem incomplete (plugin .dlls seem to be missing).
Based on a comparison of the grass6 and grass7 plugin packages, I assume that in the 32bit-package "qgis-grass-plugin7-2.12.2-1.tar.bz2" (but also in the earlier versions of the plugin (e.g. 2.12.1-1 or 2.10.1-2) the following files are missing:
apps/qgis/plugins/grassplugin7.dll
apps/qgis/grass/bin/qgis.g.browser7.exe
Anyway, many, many thanks for your packaging work, which makes the excellent OSGeo tools easily available!
Kind regards,
Stefan
-----Original Message-----
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Jürgen E. Fischer
Sent: 21. desember 2015 16:01
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] OSGeo4W-packages for GRASS 7 only in QGIS
Hi Stephan,
On Mon, 21. Dec 2015 at 10:46:54 +0000, Blumentrath, Stefan wrote:
> I was wondering what packages I have to select in order to install the
> current release of QGIS only with GRASS 7 support (meaning esp. the
> GRASS 7 plugin), cause I want to avoid confusion of users and mixed up
> GRASS mapsets (GRASS 6 /GRASS 7)...
The grass 7 plugin is only built in 32bit OSGeo4W - the 64bit version doesn't
have a stable 64bit GRASS 7 package yet - only a daily build.   That's going to
change with 7.0.3 (according to Martin Landa).
> P.S.: The current QGIS standalone installer ships only GRASS 6, so it
> is no alternative...
Yes.  I didn't want to have GRASS6 and 7 in the standalone installer and as said GRASS7 is not available in 64bit yet.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
