[Qgis-user] OSGeo4W-packages for GRASS 7 only in QGIS
Radim Blazek radim.blazek at gmail.com
Tue Dec 22 00:53:55 PST 2015
On Mon, Dec 21, 2015 at 7:50 PM, Blumentrath, Stefan
<Stefan.Blumentrath at nina.no> wrote:
> Hi Jürgen,
> Thanks for your reply.
> I am aware that the GRASS plugin is not available in 64bit (I am following yours and Martin Landa`s activity in this regards and looking forward to the 7.0.3 release, hopefully in Januar).
> I was referring to OSGeo4W 32bit (sorry for not being specific right away). In 32bit the GRASS 6 plugin works fine, the GRASS 7 plugin hower, is unfortunately not available. As mentioned the package(s) seem incomplete (plugin .dlls seem to be missing).
> Based on a comparison of the grass6 and grass7 plugin packages, I assume that in the 32bit-package "qgis-grass-plugin7-2.12.2-1.tar.bz2" (but also in the earlier versions of the plugin (e.g. 2.12.1-1 or 2.10.1-2) the following files are missing:
> apps/qgis/plugins/grassplugin7.dll
> apps/qgis/grass/bin/qgis.g.browser7.exe
There was no plugin 7 in 2.10 and thus the files were not included in
the package. Unfortunately this was forgotten somehow in 2.12. Jef
fixed that yesterday in e19ad4be, thanks.
Radim
> Anyway, many, many thanks for your packaging work, which makes the excellent OSGeo tools easily available!
> Kind regards,
> Stefan
> -----Original Message-----
> From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Jürgen E. Fischer
> Sent: 21. desember 2015 16:01
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] OSGeo4W-packages for GRASS 7 only in QGIS
> Hi Stephan,
> On Mon, 21. Dec 2015 at 10:46:54 +0000, Blumentrath, Stefan wrote:
>> I was wondering what packages I have to select in order to install the
>> current release of QGIS only with GRASS 7 support (meaning esp. the
>> GRASS 7 plugin), cause I want to avoid confusion of users and mixed up
>> GRASS mapsets (GRASS 6 /GRASS 7)...
> The grass 7 plugin is only built in 32bit OSGeo4W - the 64bit version doesn't
> have a stable 64bit GRASS 7 package yet - only a daily build.   That's going to
> change with 7.0.3 (according to Martin Landa).
>> P.S.: The current QGIS standalone installer ships only GRASS 6, so it
>> is no alternative...
> Yes.  I didn't want to have GRASS6 and 7 in the standalone installer and as said GRASS7 is not available in 64bit yet.
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
> Software Engineer           D-26506 Norden             http://www.norbit.de
> QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
