[Qgis-user] Obtaining cs2cs command line tool
Siki Zoltan siki at agt.bme.hu
Wed Dec 23 03:02:20 PST 2015
Dear Philip
probably you have installed QGIS standalone automaticly into the "Program
files" folder. Some of the utilities installed with QGI doesn't like
special characters in the path.
Solutions:
1. Use the OSGeo4W installer, you can use/install more utilities/software
2. Reinstall QGIS into a path whith no special character
Regards,
Zoltan
On Wed, 23 Dec 2015, Philip Condit wrote:
> I am using the QGIS 2.2 version (Valmiera) on a Windows 8.1 64-bit laptop.
> When I tried to open the MSYS (Minimum System) icon, I got a message that
> it could not open because the C:\Program directory could not be found.  I
> then created a C:\Program folder, and copied all of the files from the
> C:\Program Files\QGIS Valmiera\apps\msys folder to the C:\Program folder.
> I then was able to open MSYS, and get a terminal window to show up on my
> desktop.  However, when I typed cs2cs into that window, I got a message
> that the command could not be found.  How do I obtain the cs2cs command
> line tool?
