[Qgis-user] Obtaining cs2cs command line tool
Andre Joost
andre+joost at nurfuerspam.de
Wed Dec 23 07:25:57 PST 2015
Am 23.12.2015 um 11:40 schrieb Philip Condit:
> I am using the QGIS 2.2 version (Valmiera) on a Windows 8.1 64-bit laptop.
> When I tried to open the MSYS (Minimum System) icon, I got a message that
> it could not open because the C:\Program directory could not be found. I
> then created a C:\Program folder, and copied all of the files from the
> C:\Program Files\QGIS Valmiera\apps\msys folder to the C:\Program folder.
> I then was able to open MSYS, and get a terminal window to show up on my
> desktop. However, when I typed cs2cs into that window, I got a message
> that the command could not be found. How do I obtain the cs2cs command
> line tool?
To be honest, I don't know what MSYS is useful for. With a full QGIS
install, you should have an icon labelled OSGeo4W Shell. Double-click on
that, and within the command window you get, you can access cs2cs and
all GDAL coomand line tools.
HTH,
André Joost
