[Qgis-user] Exporting png or pdf from print composer does not work, empties canvas (Lyon)
Ujaval ujaval at gmail.com
Tue Dec 29 23:18:32 PST 2015
Hi Richard,
Do you have any basemaps from OpenLayers plugin in your composer? This is a
known issue with OpenLayers (http://hub.qgis.org/issues/11073). Try
removing the basemap layer and see if you are able to export. I have had
better luck with QuickMapServices plugin for basemap layers.
-Ujaval
On Tue, Dec 29, 2015 at 4:25 PM, Anita Graser <anitagraser at gmx.at> wrote:
> Hi Richard,
> That's definitely not common QGIS behavior. Do you have access to a second
> machine where you can reproduce the behavior? Can you share the problematic
> project including data? Which data sources do you use?
> Sorry, just questions and no answers at this point.
> Best wishes,
> Anita
> On Mon, Dec 28, 2015 at 3:26 AM, Richard Males <rbmales at gmail.com> wrote:
>> I am relatively new to print composer, but have been able to develop some
>> nice annotated maps.   I was able to successfully export to a png one time,
>> but since then, exports to png or pdf or svg all fail and empty the
>> canvas.  If I exit out of qgis and re-start, I can find the previously
>> populated composer with all elements intact, but I still cannot get an
>> export.  Windows 8.1, Lyon 2.12.2
>> Sometimes, not always, after attempting the export, qgis itself will
>> crash.  I have restarted the computer, same problem.
>> Is this a bug, or my ignorance?   I usually go for my ignorance, so
>> asking for help, as print composer looks to be a wonderful tool.
>> Thanks in advance
>> Dick
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151230/e706db9f/attachment.html>
