[Qgis-user] Exporting png or pdf from print composer does not work, empties canvas (Lyon)
Joris Hintjens jorishin at gmail.com
Wed Dec 30 12:27:37 PST 2015
In my experience, it can be due to bad network. When rendering the pdf, QGIS will download the needed layers again. When the connection to the servers of online map-sources fail, result will be a blank layer or missing tiles.
Joris
> Op 30 dec. 2015, om 20:48 heeft Richard Males <rbmales at gmail.com> het volgende geschreven:
> Sorry, previously posted response under wrong subject:
> Thank you.   I have been doing some additional testing, it appears to
> relate to having a few maps on the canvas that use the Open Street Map
> underlay.  The behavior is pretty much as noted in the referenced issue.
> Even with a single OSM underlay, while I do get an export, the
> underlay is not complete, i.e. jagged edges where some tiles are missing in
> the exported png, even though they do appear on the map.
> I will try QuickMapServices.plugin.
> Thanks.
> Dick
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
