[Qgis-user] (no subject)
Alexandre Neto
senhor.neto at gmail.com
Wed Feb 4 05:53:34 PST 2015
Helllo abhijeet,
To hide certain columns you need to go to the layer properties - fields
tab. Then, for each of the desired fields, you can set the Edit Widget as
Hidden.
To sort the attribute table by an especific column, all you need to do is
click over the column name. First click will sort it descending, the second
one will sort ascending.
I hope it helps,
Alexandre Neto
On Wed, Feb 4, 2015 at 1:08 PM, HISP.abhijeet <abhijeet.7777 at gmail.com>
wrote:
> hi Alexander,
> thanks for replying,
> 1st- suppose i have 10 columns and i want to see only 4 columns.
> 2nd- similarly i want to sort my rows by specifics for eg: in the Name
> column all the attributes with last name SC should be sorted.
> how can i do, what would be the expressions.
> On 4 Feb 2015 6:12 pm, "Alexandre Neto" <senhor.neto at gmail.com> wrote:
>> Hello abhijeet,
>> Please give use the example of the expression used, and the data
>> structure of your layer.
>> Best regards,
>> Alexandre Neto
>> On Wed, Feb 4, 2015 at 12:32 PM, HISP.abhijeet <abhijeet.7777 at gmail.com>
>> wrote:
>>> Hi all,
>>> i am using QGIS 2.4 and i want to do sorting and filtering in attribute
>>> table
>>> in a *vector layer*.
>>> there is an advance filtering option and i tried but failed to do or may
>>> be i am putting the expression wrong.
>>> please can any one help me on this.
>>> *Regards,*
>>> * Abhijeet*
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150204/932b2d9f/attachment.html>
