[Qgis-user] (no subject)
HISP.abhijeet
abhijeet.7777 at gmail.com
Wed Feb 4 06:20:52 PST 2015
thanks Alexander, this is helpful. one more thing though, about my 2nd
question apart from ascending and descending, is there any way i can sort
by name like names like 'abc' only.
result should be: all the names having character 'abc' should display.
On 4 Feb 2015 7:23 pm, "Alexandre Neto" <senhor.neto at gmail.com> wrote:
> Helllo abhijeet,
> To hide certain columns you need to go to the layer properties - fields
> tab. Then, for each of the desired fields, you can set the Edit Widget as
> Hidden.
> To sort the attribute table by an especific column, all you need to do is
> click over the column name. First click will sort it descending, the second
> one will sort ascending.
> I hope it helps,
> Alexandre Neto
> On Wed, Feb 4, 2015 at 1:08 PM, HISP.abhijeet <abhijeet.7777 at gmail.com>
> wrote:
>> hi Alexander,
>> thanks for replying,
>> 1st- suppose i have 10 columns and i want to see only 4 columns.
>> 2nd- similarly i want to sort my rows by specifics for eg: in the Name
>> column all the attributes with last name SC should be sorted.
>> how can i do, what would be the expressions.
>> On 4 Feb 2015 6:12 pm, "Alexandre Neto" <senhor.neto at gmail.com> wrote:
>>> Hello abhijeet,
>>> Please give use the example of the expression used, and the data
>>> structure of your layer.
>>> Best regards,
>>> Alexandre Neto
>>> On Wed, Feb 4, 2015 at 12:32 PM, HISP.abhijeet <abhijeet.7777 at gmail.com>
>>> wrote:
>>>> Hi all,
>>>> i am using QGIS 2.4 and i want to do sorting and filtering in attribute
>>>> table
>>>> in a *vector layer*.
>>>> there is an advance filtering option and i tried but failed to do or
>>>> may be i am putting the expression wrong.
>>>> please can any one help me on this.
>>>> *Regards,*
>>>> * Abhijeet*
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150204/56aec6f6/attachment.html>
