[Qgis-user] Clipping line layers
Graham Smith
myotistwo at gmail.com
Fri Feb 6 13:24:55 PST 2015
I am trying to clip some layers from Ordnance Survey vector files with
QGIS 2.6.1 on Ubuntu 14.04LTS running in Virtual Box running on WIN7.
I have these OS layers, which cover a far bigger area than I want to work
with
ST_SurfaceWater_Area
ST_Woodland
ST_Land
ST_SurfaceWater_Line
ST_Road.
I created a new polygon layer called Clip, and added a rectangular polygon
on this layer that extended over the area I wanted to clip.
The three Polygon layers clipped as expected, but with the line layers I
just get a blank shape file.
I have converted the two line layers from multipart to singlepart
I have checked that all layers are EPSG"27700-OSGB 1936/National Grid, by
double clicking on the layer and reading what the CRS is set at. I have
switched off the Project level "Enable on the fly CRS transformations and
all layers stay aligned.
I created two new shape layers using WGS84 one for the "clip" layer and a
new STsurfaceWater_line layer, just to see if it was something to do with
the CRS, but they didn't work either.
I have tried using one of the clipped layers and the intersect command to
clip the line layers but that just gives me the same blank shape file.
I have waited until the "OK" in the clip dialog box becomes active again
after a clip, to give the clip operation time to complete.
Continued searching just gives advice that repeats what I have already
found and tried.
Can anyone suggest what I might be doing wrong.
Thanks,
Graham
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150206/36605963/attachment.html>
