[Qgis-user] LecoS
Alex Mandel
tech_dev at wildintellect.com
Sun Feb 22 16:54:04 PST 2015
That's outdated info (at one point may have been true). 64bit has it.
python-scipy, 0.14.0-1
http://download.osgeo.org/osgeo4w/x86_64/versions.html
Thanks,
Alex
On 02/22/2015 03:53 PM, Mike Treglia wrote:
> Also, pretty sure on windows you need to use 32 bit for SciPy. It's pretty easy to get data into Fragstats from QGIS too as an alternative... http://www.umass.edu/landeco/research/fragstats/fragstats.html
>> On Feb 22, 2015, at 3:41 PM, Alex Mandel <tech_dev at wildintellect.com> wrote:
>> I believe OSGeo4W includes Scipy. If you used the QGIS standalone
>> installer you probably don't have it.
>> http://gis.stackexchange.com/questions/50464/how-to-install-scipy-for-qgis-standalone
>> So it doesn't have to be super hard.
>> Thanks,
>> Alex
>>> On 02/22/2015 01:31 PM, Susan Iremonger wrote:
>>> Thanks for that, sadly I think that sounds a bit beyond my capabilities. I
>>> am using Windows 8.1. I shall look into it further and see if I can get
>>> some advice on how to do that. Thanks.
>>> Susan.
>>> On Sun, Feb 22, 2015 at 9:24 PM, Alex Mandel <tech_dev at wildintellect.com>
>>> wrote:
>>>>> On 02/22/2015 01:19 PM, Susan Iremonger wrote:
>>>>> Hi, first time using this mailing list, apologies if I am making errors
>>>>> with whom to sent it to. I am asking for info about a plugin called
>>>> LecoS -
>>>>> Landscape Ecology Statistics. When I tried to load it (I am using QGIS
>>>>> Brighton) I got a message "The plugin is broken. No module named scipy".
>>>>> Does anyone know anything about the plugin and how it can be got working?
>>>>> Thanks.
>>>>> Susan
>>>> You have to install the Python Scipy library to the same python that
>>>> QGIS uses. Installation of python libraries depends on what operating
>>>> system you are using.
>>>> Thanks,
>>>> Alex
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
