[Qgis-user] LecoS
Mike Treglia
mtreglia at gmail.com
Sun Feb 22 17:28:02 PST 2015
Thanks for the correction Alex! I guess I haven't checked that in a while.
Cheers
Mike
> On Feb 22, 2015, at 6:54 PM, Alex Mandel <tech_dev at wildintellect.com> wrote:
> That's outdated info (at one point may have been true). 64bit has it.
> python-scipy, 0.14.0-1
> http://download.osgeo.org/osgeo4w/x86_64/versions.html
> Thanks,
> Alex
>> On 02/22/2015 03:53 PM, Mike Treglia wrote:
>> Also, pretty sure on windows you need to use 32 bit for SciPy. It's pretty easy to get data into Fragstats from QGIS too as an alternative... http://www.umass.edu/landeco/research/fragstats/fragstats.html
>>> On Feb 22, 2015, at 3:41 PM, Alex Mandel <tech_dev at wildintellect.com> wrote:
>>> I believe OSGeo4W includes Scipy. If you used the QGIS standalone
>>> installer you probably don't have it.
>>> http://gis.stackexchange.com/questions/50464/how-to-install-scipy-for-qgis-standalone
>>> So it doesn't have to be super hard.
>>> Thanks,
>>> Alex
>>>> On 02/22/2015 01:31 PM, Susan Iremonger wrote:
>>>> Thanks for that, sadly I think that sounds a bit beyond my capabilities. I
>>>> am using Windows 8.1. I shall look into it further and see if I can get
>>>> some advice on how to do that. Thanks.
>>>> Susan.
>>>> On Sun, Feb 22, 2015 at 9:24 PM, Alex Mandel <tech_dev at wildintellect.com>
>>>> wrote:
>>>>>> On 02/22/2015 01:19 PM, Susan Iremonger wrote:
>>>>>> Hi, first time using this mailing list, apologies if I am making errors
>>>>>> with whom to sent it to. I am asking for info about a plugin called
>>>>> LecoS -
>>>>>> Landscape Ecology Statistics. When I tried to load it (I am using QGIS
>>>>>> Brighton) I got a message "The plugin is broken. No module named scipy".
>>>>>> Does anyone know anything about the plugin and how it can be got working?
>>>>>> Thanks.
>>>>>> Susan
>>>>> You have to install the Python Scipy library to the same python that
>>>>> QGIS uses. Installation of python libraries depends on what operating
>>>>> system you are using.
>>>>> Thanks,
>>>>> Alex
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150222/b366fec9/attachment.html>
