[Qgis-user] RPM for RHEL6 based OS's please. [SEC=UNCLASSIFIED]
Bruce Bannerman B.Bannerman at bom.gov.au
Wed Jul 1 15:41:25 PDT 2015
Try the FedoraGIS repository [1].
They appear to have 2.8.2 packaged.
Bruce
[1] https://fedoraproject.org/wiki/GIS
On 1/07/2015 08:51, "qgis-user-bounces at lists.osgeo.org on behalf of
~Stack~" <qgis-user-bounces at lists.osgeo.org on behalf of
i.am.stack at gmail.com> wrote:
>Greetings,
>I never found an RPM for RHEL6 and I am _still_ struggling with getting
>QGIS to compile. I have found lots of information for Debian/Ubuntu but
>nothing really for RHEL6.
>It has taken me a lot of time to track down all of the dependencies (a
>surprising amount are not caught by the ccmake so I have to wait for the
>compile to die and track down why). I now get about ~16% into the
>compile and it dies with linker problems between two files it just
>compiled!! Doh!
>I would really appreciate some help.
>Thanks!
>The only change I made (because qt4 is too old apparently):
>$ git diff
>diff --git a/CMakeLists.txt b/CMakeLists.txt
>index ae7294c..a113b34 100644
>--- a/CMakeLists.txt
>+++ b/CMakeLists.txt
>@@ -246,7 +246,7 @@ ENDIF(WITH_QTWEBKIT)
>-SET (ENABLE_QT5 FALSE CACHE BOOL "If enabled will try to find Qt5
>before looking for Qt4")
>+SET (ENABLE_QT5 TRUE CACHE BOOL "If enabled will try to find Qt5 before
>looking for Qt4")
>Here is the basic idea of what I did after a git clone (did a fresh pull
>this morning):
>$ cd ~/Code/QGIS
>$ mkdir build-master
>$ cd build-master
>$ ccmake ..
>$ make
>Here are all the packages I had to install:
>bakefile-0.2.8-3.el6.x86_64
>cfitsio-3.240-3.el6.x86_64
>fftw2-2.1.5-21.el6.x86_64
>gdal-1.7.3-15.el6.x86_64
>gdal-devel-1.7.3-15.el6.x86_64
>gdal-java-1.7.3-15.el6.x86_64
>geos-3.3.2-1.el6.x86_64
>grass-devel-6.4.4-6.el6.x86_64
>grass-libs-6.4.4-6.el6.x86_64
>libXp-1.0.2-2.1.el6.x86_64
>libXp-devel-1.0.2-2.1.el6.x86_64
>libdap-3.11.0-1.el6.x86_64
>libgeotiff-1.2.5-6.el6.x86_64
>libgeotiff-devel-1.2.5-6.el6.x86_64
>librx-1.5-24.el6.x86_64
>libtiff-devel-3.9.4-10.el6_5.x86_64
>netcdf-4.1.1-3.el6.5.x86_64
>ogdi-3.2.0-0.14.beta2.el6.x86_64
>openmotif-2.3.3-8.el6.x86_64
>openmotif-devel-2.3.3-8.el6.x86_64
>proj-4.7.0-1.el6.x86_64
>proj-devel-4.7.0-1.el6.x86_64
>python-empy-3.3-5.el6.noarch
>unixODBC-2.2.14-14.el6.x86_64
>wxGTK-devel-2.8.12-1.el6.x86_64
>wxPython-devel-2.8.12.0-1.el6.x86_64
>xerces-c-3.0.1-20.el6.x86_64
>geos-devel-3.3.2-1.el6.x86_64
>sqlite-devel-3.6.20-1.el6.x86_64
>libspatialite-2.4.0-0.6.RC4.el6.x86_64
>libspatialite-devel-2.4.0-0.6.RC4.el6.x86_64
>qt5-qtbase-5.4.2-2.el6.x86_64
>qt5-qtbase-common-5.4.2-2.el6.noarch
>qt5-qtbase-devel-5.4.2-2.el6.x86_64
>qt5-qtbase-gui-5.4.2-2.el6.x86_64
>xcb-util-image-0.3.9-4.el6.x86_64
>xcb-util-keysyms-0.3.9-5.el6.x86_64
>xcb-util-wm-0.3.9-5.el6.x86_64
>qt5-qtsvg-5.4.2-1.el6.x86_64
>qt5-qtsvg-devel-5.4.2-1.el6.x86_64
>geoclue-0.11.1.1-0.13.20091026git73b6729.el6.x86_64
>qt5-qtdeclarative-5.4.2-2.el6.x86_64
>qt5-qtdeclarative-devel-5.4.2-2.el6.x86_64
>qt5-qtlocation-5.4.2-1.el6.x86_64
>qt5-qtlocation-devel-5.4.2-1.el6.x86_64
>qt5-qtwebkit-5.4.2-1.el6.x86_64
>qt5-qtwebkit-devel-5.4.2-1.el6.x86_64
>qt5-qttools-5.4.2-1.el6.x86_64
>qt5-qttools-common-5.4.2-1.el6.noarch
>qt5-qttools-devel-5.4.2-1.el6.x86_64
>qt5-qttools-libs-clucene-5.4.2-1.el6.x86_64
>qt5-qttools-libs-designer-5.4.2-1.el6.x86_64
>qt5-qttools-libs-designercomponents-5.4.2-1.el6.x86_64
>qt5-qttools-libs-help-5.4.2-1.el6.x86_64
>bluez-libs-4.66-1.el6.x86_64
>openal-soft-1.12.854-1.el6.x86_64
>qt5-qtconnectivity-5.4.2-1.el6.x86_64
>qt5-qtconnectivity-devel-5.4.2-1.el6.x86_64
>qt5-qtmultimedia-5.4.2-1.el6.x86_64
>qt5-qtmultimedia-devel-5.4.2-1.el6.x86_64
>qt5-qtquick1-5.4.2-1.el6.x86_64
>qt5-qtquick1-devel-5.4.2-1.el6.x86_64
>qt5-qtscript-5.4.2-1.el6.x86_64
>qt5-qtscript-devel-5.4.2-1.el6.x86_64
>qt5-qtsensors-5.4.2-1.el6.x86_64
>qt5-qtsensors-devel-5.4.2-1.el6.x86_64
>qt5-qtserialport-5.4.2-1.el6.x86_64
>qt5-qtserialport-devel-5.4.2-1.el6.x86_64
>qt5-qtwebchannel-5.4.2-1.el6.x86_64
>qt5-qtwebchannel-devel-5.4.2-1.el6.x86_64
>qt5-qtwebsockets-5.4.2-1.el6.x86_64
>qt5-qtwebsockets-devel-5.4.2-1.el6.x86_64
>qt5-qtx11extras-5.4.2-1.el6.x86_64
>qt5-qtx11extras-devel-5.4.2-1.el6.x86_64
>qt5-qtxmlpatterns-5.4.2-1.el6.x86_64
>qt5-qtxmlpatterns-devel-5.4.2-1.el6.x86_64
>PyQt4-devel-4.6.2-9.el6.x86_64
>python-devel-2.6.6-52.el6.x86_64
>sip-devel-4.9.3-1.el6.x86_64
>gsl-1.13-1.el6.x86_64
>gsl-devel-1.13-1.el6.x86_64
>expat-devel-2.0.1-11.el6_2.x86_64
>PyQwt-5.2.0-11.el6.x86_64
>PyQwt-devel-5.2.0-11.el6.x86_64
>numpy-1.4.1-9.el6.x86_64
>python-nose-0.10.4-3.1.el6.noarch
>python-setuptools-0.6.10-3.el6.noarch
>qwt-5.1.1-4.1.el6.x86_64
>qwt-devel-5.1.1-4.1.el6.x86_64
>qscintilla-2.4-1.el6.x86_64
>qscintilla-devel-2.4-1.el6.x86_64
>spatialindex-1.6.1-3.el6.x86_64
>spatialindex-devel-1.6.1-3.el6.x86_64
>qwtpolar-0.1.0-5.el6.x86_64
>qwtpolar-devel-0.1.0-5.el6.x86_64
>qt5-qttools-static-5.4.2-1.el6.x86_64
>qt-mobility-1.1.3-2.el6.x86_64
>qtwebkit-2.1.1-1.el6.x86_64
>qtwebkit-devel-2.1.1-1.el6.x86_64
>And this is as far as I have gotten with this compile:
>$ make
>Scanning dependencies of target version
>[  0%] Generating qgsversion.h
>[  0%] Built target version
>[  0%] Generating gps/moc_qgsqtlocationconnection.cpp
>[  0%] Generating flex_qgsexpressionlexer.cpp
>[  0%] Generating qgsexpressionparser.cpp
>[  0%] Generating moc_qgsapplication.cpp
>[  0%] Generating moc_qgsbrowsermodel.cpp
>[  0%] Generating moc_qgscontexthelp.cpp
>[  0%] Generating moc_qgscoordinatetransform.cpp
>[  0%] Generating moc_qgsdataitem.cpp
>[  0%] Generating moc_qgsdataprovider.cpp
>[  0%] Generating moc_qgsgml.cpp
>[  0%] Generating moc_qgsgmlschema.cpp
>[  0%] Generating moc_qgsmaplayer.cpp
>[  0%] Generating moc_qgsmaplayerlegend.cpp
>[  0%] Generating moc_qgsmaplayerregistry.cpp
>[  0%] Generating moc_qgsmaplayerstylemanager.cpp
>[  0%] Generating moc_qgsmaprenderer.cpp
>[  0%] Generating moc_qgsmaprenderercache.cpp
>[  0%] Generating moc_qgsmaprenderercustompainterjob.cpp
>[  0%] Generating moc_qgsmaprendererjob.cpp
>[  0%] Generating moc_qgsmaprendererparalleljob.cpp
>[  1%] Generating moc_qgsmaprenderersequentialjob.cpp
>[  1%] Generating moc_qgsmessageoutput.cpp
>[  1%] Generating moc_qgsmessagelog.cpp
>[  1%] Generating moc_qgsnetworkreplyparser.cpp
>[  1%] Generating moc_qgsnetworkcontentfetcher.cpp
>[  1%] Generating moc_qgsofflineediting.cpp
>[  1%] Generating moc_qgscredentials.cpp
>[  1%] Generating moc_qgspluginlayer.cpp
>[  1%] Generating moc_qgspointlocator.cpp
>[  1%] Generating moc_qgsproject.cpp
>[  1%] Generating moc_qgsrunprocess.cpp
>[  1%] Generating moc_qgsrelationmanager.cpp
>[  1%] Generating moc_qgssnappingutils.cpp
>[  1%] Generating moc_qgsvectorlayer.cpp
>[  1%] Generating moc_qgsvectorlayereditpassthrough.cpp
>[  1%] Generating moc_qgsvectorlayereditbuffer.cpp
>[  1%] Generating moc_qgsnetworkaccessmanager.cpp
>[  1%] Generating moc_qgsvectordataprovider.cpp
>[  1%] Generating moc_qgsvectorlayercache.cpp
>[  1%] Generating moc_qgsvectorlayerjoinbuffer.cpp
>[  1%] Generating moc_qgsgeometryvalidator.cpp
>[  1%] Generating moc_qgswebview.cpp
>[  1%] Generating composer/moc_qgsaddremoveitemcommand.cpp
>[  1%] Generating composer/moc_qgscomposerlegend.cpp
>[  1%] Generating composer/moc_qgscomposermap.cpp
>[  1%] Generating composer/moc_qgscomposermapitem.cpp
>[  1%] Generating composer/moc_qgscomposermapgrid.cpp
>[  1%] Generating composer/moc_qgscomposermapoverview.cpp
>[  1%] Generating composer/moc_qgscomposerpicture.cpp
>[  1%] Generating composer/moc_qgscomposerscalebar.cpp
>[  1%] Generating composer/moc_qgscomposerobject.cpp
>[  1%] Generating composer/moc_qgscomposeritem.cpp
>[  2%] Generating composer/moc_qgscomposeritemgroup.cpp
>[  2%] Generating composer/moc_qgscomposermousehandles.cpp
>[  2%] Generating composer/moc_qgscomposerlabel.cpp
>[  2%] Generating composer/moc_qgscomposershape.cpp
>[  2%] Generating composer/moc_qgscomposerattributetable.cpp
>[  2%] Generating composer/moc_qgscomposerattributetablev2.cpp
>[  2%] Generating composer/moc_qgscomposerattributetablemodel.cpp
>[  2%] Generating composer/moc_qgscomposerattributetablemodelv2.cpp
>[  2%] Generating composer/moc_qgscomposertable.cpp
>[  2%] Generating composer/moc_qgscomposertablev2.cpp
>[  2%] Generating composer/moc_qgscomposertablecolumn.cpp
>[  2%] Generating composer/moc_qgscomposertexttable.cpp
>[  2%] Generating composer/moc_qgscomposerhtml.cpp
>[  2%] Generating composer/moc_qgscomposermultiframe.cpp
>[  2%] Generating composer/moc_qgscomposereffect.cpp
>[  2%] Generating composer/moc_qgsatlascomposition.cpp
>[  2%] Generating composer/moc_qgscomposermodel.cpp
>[  2%] Generating composer/moc_qgscomposition.cpp
>[  2%] Generating composer/moc_qgslegendmodel.cpp
>[  2%] Generating raster/moc_qgsrasterlayer.cpp
>[  2%] Generating raster/moc_qgsrasterdataprovider.cpp
>[  2%] Generating gps/moc_qgsgpsconnection.cpp
>[  2%] Generating gps/moc_qgsgpsdetector.cpp
>[  2%] Generating gps/moc_qgsnmeaconnection.cpp
>[  2%] Generating gps/moc_qgsgpsdconnection.cpp
>[  2%] Generating symbology-ng/moc_qgscptcityarchive.cpp
>[  2%] Generating symbology-ng/moc_qgssvgcache.cpp
>[  2%] Generating symbology-ng/moc_qgsstylev2.cpp
>[  2%] Generating layertree/moc_qgslayertreegroup.cpp
>[  2%] Generating layertree/moc_qgslayertreelayer.cpp
>[  2%] Generating layertree/moc_qgslayertreemodel.cpp
>[  2%] Generating layertree/moc_qgslayertreemodellegendnode.cpp
>[  2%] Generating layertree/moc_qgslayertreenode.cpp
>[  3%] Generating layertree/moc_qgslayertreeregistrybridge.cpp
>[  3%] Generating gps/qextserialport/moc_qextserialport.cpp
>[  3%] Generating gps/qextserialport/moc_qextserialenumerator.cpp
>Scanning dependencies of target qgis_core
>[  3%] Building CXX object
>src/core/CMakeFiles/qgis_core.dir/gps/qgsgpsconnection.cpp.o
>src/core/CMakeFiles/qgis_core.dir/gps/qgsgpsconnectionregistry.cpp.o
>src/core/CMakeFiles/qgis_core.dir/gps/qgsnmeaconnection.cpp.o
>src/core/CMakeFiles/qgis_core.dir/gps/qgsgpsdconnection.cpp.o
>src/core/CMakeFiles/qgis_core.dir/gps/qgsgpsdetector.cpp.o
>[  3%] Building C object src/core/CMakeFiles/qgis_core.dir/gps/parse.c.o
>src/core/CMakeFiles/qgis_core.dir/gps/sentence.c.o
>[  3%] Building C object src/core/CMakeFiles/qgis_core.dir/gps/info.c.o
>[  3%] Building C object src/core/CMakeFiles/qgis_core.dir/gps/time.c.o
>[  3%] Building C object src/core/CMakeFiles/qgis_core.dir/gps/gmath.c.o
>[  3%] Building C object src/core/CMakeFiles/qgis_core.dir/gps/tok.c.o
>[  3%] Building C object src/core/CMakeFiles/qgis_core.dir/gps/context.c.o
>src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgssymbolv2.cpp.o
>src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgssymbollayerv2.cpp.o
>/home/user/Code/QGIS/src/core/symbology-ng/qgssymbollayerv2.cpp: In
>member function Œvirtual const QgsExpression*
>QgsSymbolLayerV2::dataDefinedProperty(const QString&) const¹:
>/home/user/Code/QGIS/src/core/symbology-ng/qgssymbollayerv2.cpp:95:
>warning: Œvirtual QgsExpression* QgsSymbolLayerV2::expression(const
>QString&) const¹ is deprecated (declared at
>/home/user/Code/QGIS/src/core/symbology-ng/qgssymbollayerv2.h:262)
>src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgssymbollayerv2registry.cp
>p.o
>src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgssymbollayerv2utils.cpp.o
>src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgslegendsymbolitemv2.cpp.o
>src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgslinesymbollayerv2.cpp.o
>src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgsmarkersymbollayerv2.cpp.
>o
>src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgsfillsymbollayerv2.cpp.o
>src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgsrendererv2.cpp.o
>src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgsrendererv2registry.cpp.o
>src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgssinglesymbolrendererv2.c
>pp.o
>src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgscategorizedsymbolrendere
>rv2.cpp.o
>src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgsgraduatedsymbolrendererv
>2.cpp.o
>src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgsrulebasedrendererv2.cpp.
>o
>src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgsheatmaprenderer.cpp.o
>src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgsinvertedpolygonrenderer.
>cpp.o
>[  4%] Building CXX object
>src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgsvectorcolorrampv2.cpp.o
>src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgscptcityarchive.cpp.o
>src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgsstylev2.cpp.o
>src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgssymbologyv2conversion.cp
>p.o
>src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgssvgcache.cpp.o
>src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgsellipsesymbollayerv2.cpp
>.o
>src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgspointdisplacementrendere
>r.cpp.o
>src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgsvectorfieldsymbollayer.c
>pp.o
>src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgscolorbrewerpalette.cpp.o
>src/core/CMakeFiles/qgis_core.dir/diagram/qgsdiagram.cpp.o
>src/core/CMakeFiles/qgis_core.dir/diagram/qgspiediagram.cpp.o
>src/core/CMakeFiles/qgis_core.dir/diagram/qgstextdiagram.cpp.o
>src/core/CMakeFiles/qgis_core.dir/diagram/qgshistogramdiagram.cpp.o
>src/core/CMakeFiles/qgis_core.dir/effects/qgsimageoperation.cpp.o
>src/core/CMakeFiles/qgis_core.dir/effects/qgspainteffect.cpp.o
>src/core/CMakeFiles/qgis_core.dir/effects/qgseffectstack.cpp.o
>src/core/CMakeFiles/qgis_core.dir/effects/qgsblureffect.cpp.o
>src/core/CMakeFiles/qgis_core.dir/effects/qgsshadoweffect.cpp.o
>src/core/CMakeFiles/qgis_core.dir/effects/qgsgloweffect.cpp.o
>src/core/CMakeFiles/qgis_core.dir/effects/qgspainteffectregistry.cpp.o
>src/core/CMakeFiles/qgis_core.dir/effects/qgstransformeffect.cpp.o
>src/core/CMakeFiles/qgis_core.dir/effects/qgscoloreffect.cpp.o
>src/core/CMakeFiles/qgis_core.dir/layertree/qgslayertreegroup.cpp.o
>src/core/CMakeFiles/qgis_core.dir/layertree/qgslayertreelayer.cpp.o
>src/core/CMakeFiles/qgis_core.dir/layertree/qgslayertreemodel.cpp.o
>src/core/CMakeFiles/qgis_core.dir/layertree/qgslayertreemodellegendnode.cp
>p.o
>src/core/CMakeFiles/qgis_core.dir/layertree/qgslayertreenode.cpp.o
>src/core/CMakeFiles/qgis_core.dir/layertree/qgslayertreeregistrybridge.cpp
>.o
>src/core/CMakeFiles/qgis_core.dir/layertree/qgslayertreeutils.cpp.o
>[  4%] Building CXX object src/core/CMakeFiles/qgis_core.dir/qgis.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsapplication.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsattributeaction.cpp.o
>/home/user/Code/QGIS/src/core/qgsattributeaction.cpp: In member function
>Œbool QgsAttributeAction::readXML(const QDomNode&)¹:
>/home/user/Code/QGIS/src/core/qgsattributeaction.cpp:263: warning:
>comparison between signed and unsigned integer expressions
>[  5%] Building CXX object
>src/core/CMakeFiles/qgis_core.dir/qgsbrowsermodel.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgscachedfeatureiterator.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgscacheindex.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgscacheindexfeatureid.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsclipper.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgscolorscheme.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgscolorschemeregistry.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgscontexthelp.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgscontexthelp_texts.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgscoordinatereferencesystem.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgscoordinatetransform.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgscredentials.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsdartmeasurement.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgscrscache.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsdatadefined.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsdatasourceuri.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsdataitem.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsdataitemprovider.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsdataitemproviderregistry.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsdatumtransformstore.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsdbfilterproxymodel.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsdiagramrendererv2.cpp.o
>/home/user/Code/QGIS/src/core/qgsdiagramrendererv2.cpp: In member
>function Œvoid QgsDiagramSettings::readXML(const QDomElement&, const
>QgsVectorLayer*)¹:
>/home/user/Code/QGIS/src/core/qgsdiagramrendererv2.cpp:168: warning:
>src/core/CMakeFiles/qgis_core.dir/qgsdistancearea.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgserror.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsexpression.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsexpression_texts.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsexpressionfieldbuffer.cpp.o
>/home/user/Code/QGIS/src/core/qgsexpressionfieldbuffer.cpp: In member
>function Œvoid QgsExpressionFieldBuffer::readXml(const QDomNode&)¹:
>/home/user/Code/QGIS/src/core/qgsexpressionfieldbuffer.cpp:72: warning:
>src/core/CMakeFiles/qgis_core.dir/qgsfeature.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsfeatureiterator.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsfeaturerequest.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsfeaturestore.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsfield.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsfontutils.cpp.o
>[  6%] Building CXX object
>src/core/CMakeFiles/qgis_core.dir/qgsgeometrycache.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsgeometrysimplifier.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsgeometryvalidator.cpp.o
>[  6%] Building CXX object src/core/CMakeFiles/qgis_core.dir/qgsgml.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsgmlschema.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgshistogram.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgslayerdefinition.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgslabel.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgslabelattributes.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgslabelsearchtree.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgslegacyhelpers.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgslegendrenderer.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgslegendsettings.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgslogger.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsmaphittest.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsmaplayer.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsmaplayerlegend.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsmaplayerregistry.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsmaplayerstylemanager.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsmaprenderer.cpp.o
>/home/user/Code/QGIS/src/core/qgsmaprenderer.cpp: In member function
>Œvoid QgsMapRenderer::adjustExtentToSize()¹:
>/home/user/Code/QGIS/src/core/qgsmaprenderer.cpp:229: warning: Œvoid
>QgsMapToPixel::setParameters(double, double, double, double)¹ is
>deprecated (declared at /home/user/Code/QGIS/src/core/qgsmaptopixel.h:199)
>Œvoid QgsMapRenderer::render(QPainter*, double*)¹:
>/home/user/Code/QGIS/src/core/qgsmaprenderer.cpp:491: warning: Œvoid
>QgsMapToPixel::setYMaximum(double)¹ is deprecated (declared at
>/home/user/Code/QGIS/src/core/qgsmaptopixel.h:177)
>Œvoid QgsMapRenderer::setProjectionsEnabled(bool)¹:
>/home/user/Code/QGIS/src/core/qgsmaprenderer.cpp:665: warning: Œvoid
>QgsMapRenderer::hasCrsTransformEnabled(bool)¹ is deprecated (declared at
>/home/user/Code/QGIS/src/core/qgsmaprenderer.h:344)
>src/core/CMakeFiles/qgis_core.dir/qgsmaprenderercache.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsmaprenderercustompainterjob.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsmaprendererjob.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsmaprendererparalleljob.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsmaprenderersequentialjob.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsmapsettings.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsmaptopixel.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsmaptopixelgeometrysimplifier.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsmessagelog.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsmessageoutput.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsmimedatautils.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsmultirenderchecker.cpp.o
>[  7%] Building CXX object
>src/core/CMakeFiles/qgis_core.dir/qgsnetworkaccessmanager.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsnetworkcontentfetcher.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsnetworkreplyparser.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsobjectcustomproperties.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsofflineediting.cpp.o
>/home/user/Code/QGIS/src/core/qgsofflineediting.cpp: In member function
>ŒQgsVectorLayer* QgsOfflineEditing::copyVectorLayer(QgsVectorLayer*,
>sqlite3*, const QString&)¹:
>/home/user/Code/QGIS/src/core/qgsofflineediting.cpp:565: warning: Œbool
>QgsVectorLayer::hasLabelsEnabled() const¹ is deprecated (declared at
>/home/user/Code/QGIS/src/core/qgsvectorlayer.h:1244)
>src/core/CMakeFiles/qgis_core.dir/qgsogcutils.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsowsconnection.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgspaintenginehack.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgspallabeling.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgspluginlayer.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgspluginlayerregistry.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgspoint.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgspointlocator.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsproject.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsprojectfiletransform.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsprojectproperty.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsprojectversion.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsprovidercountcalcevent.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsproviderextentcalcevent.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsprovidermetadata.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsproviderregistry.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgspythonrunner.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsrelation.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsrelationmanager.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsrenderchecker.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsrendercontext.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsrectangle.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsrunprocess.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsscalecalculator.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsscaleexpression.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsscaleutils.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgssimplifymethod.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgssnapper.cpp.o
>[  8%] Building CXX object
>src/core/CMakeFiles/qgis_core.dir/qgssnappingutils.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsspatialindex.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsstatisticalsummary.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsstringutils.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgstransaction.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgstolerance.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsvectordataprovider.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsvectorfilewriter.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsvectorlayer.cpp.o
>/home/user/Code/QGIS/src/core/qgsvectorlayer.cpp: In member function
>Œvirtual bool QgsVectorLayer::readSymbology(const QDomNode&, QString&)¹:
>/home/user/Code/QGIS/src/core/qgsvectorlayer.cpp:1604: warning: Œvoid
>QgsVectorLayer::enableLabels(bool)¹ is deprecated (declared at
>/home/user/Code/QGIS/src/core/qgsvectorlayer.cpp:1167)
>/home/user/Code/QGIS/src/core/qgsvectorlayer.cpp:1608: warning: Œvoid
>Œvirtual bool QgsVectorLayer::writeSymbology(QDomNode&, QDomDocument&,
>QString&) const¹:
>/home/user/Code/QGIS/src/core/qgsvectorlayer.cpp:1863: warning: Œbool
>/home/user/Code/QGIS/src/core/qgsvectorlayer.cpp:1172)
>ŒQgsVectorLayer::EditType QgsVectorLayer::editType(int)¹:
>/home/user/Code/QGIS/src/core/qgsvectorlayer.cpp:2636: warning: Œstatic
>QgsVectorLayer::EditType QgsLegacyHelpers::convertEditType(const
>QString&, const QgsEditorWidgetConfig&, QgsVectorLayer*, const
>QString&)¹ is deprecated (declared at
>/home/user/Code/QGIS/src/core/qgslegacyhelpers.h:27)
>Œvoid QgsVectorLayer::setEditType(int, QgsVectorLayer::EditType)¹:
>/home/user/Code/QGIS/src/core/qgsvectorlayer.cpp:2648: warning: Œstatic
>const QString
>QgsLegacyHelpers::convertEditType(QgsVectorLayer::EditType,
>QgsEditorWidgetConfig&, QgsVectorLayer*, const QString&, const
>QDomElement&)¹ is deprecated (declared at
>/home/user/Code/QGIS/src/core/qgslegacyhelpers.h:26)
>src/core/CMakeFiles/qgis_core.dir/qgsvectorlayercache.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsvectorlayereditbuffer.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsvectorlayereditpassthrough.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsvectorlayereditutils.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsvectorlayerfeatureiterator.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsvectorlayerimport.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsvectorlayerjoinbuffer.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsvectorlayerrenderer.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsvectorlayerundocommand.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsvectorsimplifymethod.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsxmlutils.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsslconnect.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgslocalec.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgsaddremoveitemcommand.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgsaddremovemultiframecommand.c
>pp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposermultiframecommand.cp
>p.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposerarrow.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposerframe.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposermousehandles.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposerobject.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposerutils.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposeritem.cpp.o
>/home/user/Code/QGIS/src/core/composer/qgscomposeritem.cpp: In member
>function Œbool QgsComposerItem::imageSizeConsideringRotation(double&,
>double&) const¹:
>/home/user/Code/QGIS/src/core/composer/qgscomposeritem.cpp:1115:
>warning: Œbool QgsComposerItem::imageSizeConsideringRotation(double&,
>double&, double) const¹ is deprecated (declared at
>/home/user/Code/QGIS/src/core/composer/qgscomposeritem.h:713)
>double&, double) const¹:
>/home/user/Code/QGIS/src/core/composer/qgscomposeritem.cpp:1146:
>warning: Œbool
>QgsComposerItem::cornerPointOnRotatedAndScaledRect(double&, double&,
>double, double, double) const¹ is deprecated (declared at
>/home/user/Code/QGIS/src/core/composer/qgscomposeritem.h:732)
>/home/user/Code/QGIS/src/core/composer/qgscomposeritem.cpp:1150:
>warning: Œbool
>/home/user/Code/QGIS/src/core/composer/qgscomposeritem.cpp:1154:
>warning: Œbool
>/home/user/Code/QGIS/src/core/composer/qgscomposeritem.cpp:1158:
>warning: Œbool
>function Œbool
>double, double) const¹:
>/home/user/Code/QGIS/src/core/composer/qgscomposeritem.cpp:1194:
>warning: Œbool
>function Œvoid QgsComposerItem::sizeChangedByRotation(double&, double&)¹:
>/home/user/Code/QGIS/src/core/composer/qgscomposeritem.cpp:1239:
>warning: Œvoid QgsComposerItem::sizeChangedByRotation(double&, double&,
>/home/user/Code/QGIS/src/core/composer/qgscomposeritem.h:742)
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposeritemcommand.cpp.o
>[  9%] Building CXX object
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposeritemgroup.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposerlabel.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposerlegenditem.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposerpicture.cpp.o
>/home/user/Code/QGIS/src/core/composer/qgscomposerpicture.cpp: In member
>function Œbool QgsComposerPicture::imageSizeConsideringRotation(double&,
>double&) const¹:
>/home/user/Code/QGIS/src/core/composer/qgscomposerpicture.cpp:841:
>function Œbool
>QgsComposerPicture::cornerPointOnRotatedAndScaledRect(double&, double&,
>/home/user/Code/QGIS/src/core/composer/qgscomposerpicture.cpp:849:
>warning: Œbool
>function Œvoid QgsComposerPicture::sizeChangedByRotation(double&,
>double&)¹:
>/home/user/Code/QGIS/src/core/composer/qgscomposerpicture.cpp:857:
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposermap.cpp.o
>/home/user/Code/QGIS/src/core/composer/qgscomposermap.cpp: In member
>function Œconst QgsMapRenderer* QgsComposerMap::mapRenderer() const¹:
>/home/user/Code/QGIS/src/core/composer/qgscomposermap.cpp:518: warning:
>ŒQgsMapRenderer* QgsComposition::mapRenderer()¹ is deprecated (declared
>at /home/user/Code/QGIS/src/core/composer/qgscomposition.h:393)
>function Œbool QgsComposerMap::imageSizeConsideringRotation(double&,
>double&) const¹:
>/home/user/Code/QGIS/src/core/composer/qgscomposermap.cpp:2342: warning:
>Œbool QgsComposerItem::imageSizeConsideringRotation(double&, double&,
>function Œbool
>QgsComposerMap::cornerPointOnRotatedAndScaledRect(double&, double&,
>/home/user/Code/QGIS/src/core/composer/qgscomposermap.cpp:2350: warning:
>Œbool QgsComposerItem::cornerPointOnRotatedAndScaledRect(double&,
>double&, double, double, double) const¹ is deprecated (declared at
>function Œvoid QgsComposerMap::sizeChangedByRotation(double&, double&)¹:
>/home/user/Code/QGIS/src/core/composer/qgscomposermap.cpp:2358: warning:
>Œvoid QgsComposerItem::sizeChangedByRotation(double&, double&, double)¹
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposermapitem.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposermapgrid.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposermapoverview.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposertable.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposertablev2.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposertablecolumn.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposerattributetable.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposerattributetablev2.cpp
>.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposerattributetablemodel.
>cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposerattributetablemodelv
>2.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposertexttable.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposerscalebar.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposershape.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposereffect.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgsatlascomposition.cpp.o
>/home/user/Code/QGIS/src/core/composer/qgsatlascomposition.cpp: In
>member function Œbool QgsAtlasComposition::fixedScale() const¹:
>/home/user/Code/QGIS/src/core/composer/qgsatlascomposition.cpp:836:
>warning: ŒQgsComposerMap* QgsAtlasComposition::composerMap() const¹ is
>/home/user/Code/QGIS/src/core/composer/qgsatlascomposition.cpp:116)
>/home/user/Code/QGIS/src/core/composer/qgsatlascomposition.cpp:842:
>warning: Œbool QgsComposerMap::atlasFixedScale() const¹ is deprecated
>(declared at /home/user/Code/QGIS/src/core/composer/qgscomposermap.h:706)
>member function Œvoid QgsAtlasComposition::setFixedScale(bool)¹:
>/home/user/Code/QGIS/src/core/composer/qgsatlascomposition.cpp:848:
>member function Œfloat QgsAtlasComposition::margin() const¹:
>/home/user/Code/QGIS/src/core/composer/qgsatlascomposition.cpp:860:
>member function Œvoid QgsAtlasComposition::setMargin(float)¹:
>/home/user/Code/QGIS/src/core/composer/qgsatlascomposition.cpp:872:
>src/core/CMakeFiles/qgis_core.dir/composer/qgslegendmodel.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposerlegend.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposerlegendstyle.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgspaperitem.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgsscalebarstyle.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgsdoubleboxscalebarstyle.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgsnumericscalebarstyle.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgssingleboxscalebarstyle.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgsticksscalebarstyle.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposerhtml.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposermultiframe.cpp.o
>/home/user/Code/QGIS/src/core/composer/qgscomposermultiframe.cpp: In
>member function Œvirtual void QgsComposerMultiFrame::render(QPainter*,
>const QRectF&, int)¹:
>/home/user/Code/QGIS/src/core/composer/qgscomposermultiframe.cpp:56:
>warning: Œvirtual void QgsComposerMultiFrame::render(QPainter*, const
>QRectF&)¹ is deprecated (declared at
>/home/user/Code/QGIS/src/core/composer/qgscomposermultiframe.cpp:44)
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposermodel.cpp.o
>[ 10%] Building CXX object
>src/core/CMakeFiles/qgis_core.dir/composer/qgscomposition.cpp.o
>src/core/CMakeFiles/qgis_core.dir/dxf/qgsdxfexport.cpp.o
>src/core/CMakeFiles/qgis_core.dir/dxf/qgsdxfpaintdevice.cpp.o
>/home/user/Code/QGIS/src/core/dxf/qgsdxfpaintdevice.cpp: In member
>function Œvirtual int
>QgsDxfPaintDevice::metric(QPaintDevice::PaintDeviceMetric) const¹:
>/home/user/Code/QGIS/src/core/dxf/qgsdxfpaintdevice.cpp:37: warning:
>enumeration value ŒPdmDevicePixelRatio¹ not handled in switch
>src/core/CMakeFiles/qgis_core.dir/dxf/qgsdxfpaintengine.cpp.o
>src/core/CMakeFiles/qgis_core.dir/dxf/qgsdxfpallabeling.cpp.o
>/home/user/Code/QGIS/src/core/dxf/qgsdxfpallabeling.cpp: In constructor
>ŒQgsDxfPalLabeling::QgsDxfPalLabeling(QgsDxfExport*, const
>QgsRectangle&, double, QGis::UnitType)¹:
>/home/user/Code/QGIS/src/core/dxf/qgsdxfpallabeling.cpp:54: warning:
>ŒQgsMapToPixel::QgsMapToPixel(double, double, double, double)¹ is
>deprecated (declared at /home/user/Code/QGIS/src/core/qgsmaptopixel.h:45)
>src/core/CMakeFiles/qgis_core.dir/pal/costcalculator.cpp.o
>src/core/CMakeFiles/qgis_core.dir/pal/feature.cpp.o
>src/core/CMakeFiles/qgis_core.dir/pal/geomfunction.cpp.o
>src/core/CMakeFiles/qgis_core.dir/pal/labelposition.cpp.o
>src/core/CMakeFiles/qgis_core.dir/pal/layer.cpp.o
>[ 10%] Building CXX object src/core/CMakeFiles/qgis_core.dir/pal/pal.cpp.o
>src/core/CMakeFiles/qgis_core.dir/pal/palstat.cpp.o
>src/core/CMakeFiles/qgis_core.dir/pal/pointset.cpp.o
>src/core/CMakeFiles/qgis_core.dir/pal/priorityqueue.cpp.o
>src/core/CMakeFiles/qgis_core.dir/pal/problem.cpp.o
>src/core/CMakeFiles/qgis_core.dir/pal/util.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgscliptominmaxenhancement.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgsraster.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgsrasterblock.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgscolorrampshader.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgscontrastenhancement.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgscontrastenhancementfunction.cp
>p.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgsrasterdataprovider.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgslinearminmaxenhancement.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgslinearminmaxenhancementwithcli
>p.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgspseudocolorshader.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgsrasterprojector.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgsrasterchecker.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgsrasteridentifyresult.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgsrasterinterface.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgsrasteriterator.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgsrasterlayer.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgsrasterlayerrenderer.cpp.o
>[ 11%] Building CXX object
>src/core/CMakeFiles/qgis_core.dir/raster/qgsrasternuller.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgsrastertransparency.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgsrasterpipe.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgsrasterrange.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgsrastershader.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgsrastershaderfunction.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgsrasterdrawer.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgsrasterfilewriter.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgsrasterresamplefilter.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgsrasterrendererregistry.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgsrasterrenderer.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgsbilinearrasterresampler.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgscubicrasterresampler.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgspalettedrasterrenderer.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgsmultibandcolorrenderer.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgssinglebandcolordatarenderer.cp
>p.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgssinglebandgrayrenderer.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgssinglebandpseudocolorrenderer.
>cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgsbrightnesscontrastfilter.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/qgshuesaturationfilter.cpp.o
>src/core/CMakeFiles/qgis_core.dir/geometry/qgsabstractgeometryv2.cpp.o
>src/core/CMakeFiles/qgis_core.dir/geometry/qgscircularstringv2.cpp.o
>src/core/CMakeFiles/qgis_core.dir/geometry/qgscompoundcurvev2.cpp.o
>src/core/CMakeFiles/qgis_core.dir/geometry/qgscurvev2.cpp.o
>src/core/CMakeFiles/qgis_core.dir/geometry/qgscurvepolygonv2.cpp.o
>src/core/CMakeFiles/qgis_core.dir/geometry/qgsgeometry.cpp.o
>src/core/CMakeFiles/qgis_core.dir/geometry/qgsgeometrycollectionv2.cpp.o
>src/core/CMakeFiles/qgis_core.dir/geometry/qgsgeometryeditutils.cpp.o
>src/core/CMakeFiles/qgis_core.dir/geometry/qgsgeometryfactory.cpp.o
>src/core/CMakeFiles/qgis_core.dir/geometry/qgsgeometryutils.cpp.o
>src/core/CMakeFiles/qgis_core.dir/geometry/qgsgeos.cpp.o
>src/core/CMakeFiles/qgis_core.dir/geometry/qgspointv2.cpp.o
>[ 12%] Building CXX object
>src/core/CMakeFiles/qgis_core.dir/geometry/qgspolygonv2.cpp.o
>src/core/CMakeFiles/qgis_core.dir/geometry/qgslinestringv2.cpp.o
>src/core/CMakeFiles/qgis_core.dir/geometry/qgsmulticurvev2.cpp.o
>src/core/CMakeFiles/qgis_core.dir/geometry/qgsmultilinestringv2.cpp.o
>src/core/CMakeFiles/qgis_core.dir/geometry/qgsmultipointv2.cpp.o
>src/core/CMakeFiles/qgis_core.dir/geometry/qgsmultipolygonv2.cpp.o
>src/core/CMakeFiles/qgis_core.dir/geometry/qgsmultisurfacev2.cpp.o
>src/core/CMakeFiles/qgis_core.dir/geometry/qgswkbptr.cpp.o
>src/core/CMakeFiles/qgis_core.dir/geometry/qgswkbtypes.cpp.o
>src/core/CMakeFiles/qgis_core.dir/gps/qextserialport/qextserialport.cpp.o
>src/core/CMakeFiles/qgis_core.dir/gps/qextserialport/qextserialenumerator.
>cpp.o
>src/core/CMakeFiles/qgis_core.dir/gps/qextserialport/posix_qextserialport.
>cpp.o
>src/core/CMakeFiles/qgis_core.dir/gps/qgsqtlocationconnection.cpp.o
>/home/user/Code/QGIS/src/core/gps/qgsqtlocationconnection.cpp: In member
>function Œvirtual void QgsQtLocationConnection::parseData()¹:
>/home/user/Code/QGIS/src/core/gps/qgsqtlocationconnection.cpp:87:
>warning: statement has no effect
>/home/user/Code/QGIS/src/core/gps/qgsqtlocationconnection.cpp:88:
>/home/user/Code/QGIS/src/core/gps/qgsqtlocationconnection.cpp:89:
>/home/user/Code/QGIS/src/core/gps/qgsqtlocationconnection.cpp:91:
>/home/user/Code/QGIS/src/core/gps/qgsqtlocationconnection.cpp:92:
>/home/user/Code/QGIS/src/core/gps/qgsqtlocationconnection.cpp:93:
>src/core/CMakeFiles/qgis_core.dir/flex_qgsexpressionlexer.cpp.o
>src/core/CMakeFiles/qgis_core.dir/qgsexpressionparser.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgsapplication.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgsbrowsermodel.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgscontexthelp.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgscoordinatetransform.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgsdataitem.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgsdataprovider.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgsgml.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgsgmlschema.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgsmaplayer.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgsmaplayerlegend.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgsmaplayerregistry.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgsmaplayerstylemanager.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgsmaprenderer.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgsmaprenderercache.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgsmaprenderercustompainterjob.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgsmaprendererjob.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgsmaprendererparalleljob.cpp.o
>[ 13%] Building CXX object
>src/core/CMakeFiles/qgis_core.dir/moc_qgsmaprenderersequentialjob.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgsmessageoutput.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgsmessagelog.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgsnetworkreplyparser.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgsnetworkcontentfetcher.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgsofflineediting.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgscredentials.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgspluginlayer.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgspointlocator.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgsproject.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgsrunprocess.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgsrelationmanager.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgssnappingutils.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgsvectorlayer.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgsvectorlayereditpassthrough.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgsvectorlayereditbuffer.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgsnetworkaccessmanager.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgsvectordataprovider.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgsvectorlayercache.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgsvectorlayerjoinbuffer.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgsgeometryvalidator.cpp.o
>src/core/CMakeFiles/qgis_core.dir/moc_qgswebview.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/moc_qgsaddremoveitemcommand.cpp
>.o
>src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposerlegend.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposermap.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposermapitem.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposermapgrid.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposermapoverview.cpp.
>o
>src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposerpicture.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposerscalebar.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposerobject.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposeritem.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposeritemgroup.cpp.o
>[ 14%] Building CXX object
>src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposermousehandles.cpp
>.o
>src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposerlabel.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposershape.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposerattributetable.c
>pp.o
>src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposerattributetablev2
>.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposerattributetablemo
>del.cpp.o
>delv2.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposertable.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposertablev2.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposertablecolumn.cpp.
>o
>src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposertexttable.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposerhtml.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposermultiframe.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposereffect.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/moc_qgsatlascomposition.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposermodel.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposition.cpp.o
>src/core/CMakeFiles/qgis_core.dir/composer/moc_qgslegendmodel.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/moc_qgsrasterlayer.cpp.o
>src/core/CMakeFiles/qgis_core.dir/raster/moc_qgsrasterdataprovider.cpp.o
>src/core/CMakeFiles/qgis_core.dir/gps/moc_qgsgpsconnection.cpp.o
>src/core/CMakeFiles/qgis_core.dir/gps/moc_qgsgpsdetector.cpp.o
>src/core/CMakeFiles/qgis_core.dir/gps/moc_qgsnmeaconnection.cpp.o
>src/core/CMakeFiles/qgis_core.dir/gps/moc_qgsgpsdconnection.cpp.o
>src/core/CMakeFiles/qgis_core.dir/symbology-ng/moc_qgscptcityarchive.cpp.o
>src/core/CMakeFiles/qgis_core.dir/symbology-ng/moc_qgssvgcache.cpp.o
>src/core/CMakeFiles/qgis_core.dir/symbology-ng/moc_qgsstylev2.cpp.o
>src/core/CMakeFiles/qgis_core.dir/layertree/moc_qgslayertreegroup.cpp.o
>src/core/CMakeFiles/qgis_core.dir/layertree/moc_qgslayertreelayer.cpp.o
>src/core/CMakeFiles/qgis_core.dir/layertree/moc_qgslayertreemodel.cpp.o
>src/core/CMakeFiles/qgis_core.dir/layertree/moc_qgslayertreemodellegendnod
>e.cpp.o
>src/core/CMakeFiles/qgis_core.dir/layertree/moc_qgslayertreenode.cpp.o
>[ 15%] Building CXX object
>src/core/CMakeFiles/qgis_core.dir/layertree/moc_qgslayertreeregistrybridge
>.cpp.o
>src/core/CMakeFiles/qgis_core.dir/gps/qextserialport/moc_qextserialport.cp
>p.o
>src/core/CMakeFiles/qgis_core.dir/gps/qextserialport/moc_qextserialenumera
>tor.cpp.o
>src/core/CMakeFiles/qgis_core.dir/gps/moc_qgsqtlocationconnection.cpp.o
>Linking CXX shared library ../../output/lib/libqgis_core.so
>CMakeFiles/qgis_core.dir/composer/qgscomposerlabel.cpp.o: In function
>`QgsComposerLabel::paint(QPainter*, QStyleOptionGraphicsItem const*,
>QWidget*)':
>qgscomposerlabel.cpp:(.text+0xe79): undefined reference to
>`QWebFrame::render(QPainter*)'
>CMakeFiles/qgis_core.dir/composer/qgscomposerhtml.cpp.o: In function
>`QgsComposerHtml::renderCachedImage()':
>qgscomposerhtml.cpp:(.text+0x153f): undefined reference to
>collect2: ld returned 1 exit status
>make[2]: *** [output/lib/libqgis_core.so.2.11.0] Error 1
>make[1]: *** [src/core/CMakeFiles/qgis_core.dir/all] Error 2
>make: *** [all] Error 2
