[Qgis-user] QGIS instalation and uninstallation issues
Bo Victor Thomsen bo.victor.thomsen at gmail.com
Mon Jul 20 07:44:32 PDT 2015
Ah , ok, now I understand. I didn't consider using the variables or
"tokens" in a default installation from the start. It could be
implemented (not used with the default installation) in one version and
tested by using the --configpath qualifier with a manually customized
qgis2.ini file.
Thanks for your patience Jürgen. I think, I'll write my suggestions in a
more formalized way and put it on the wish list (If it ain't there already)
Regards
Bo Victor Thomsen
AestasGIS
Denmark
On 20-07-2015 14:24, Jürgen E. Fischer wrote:
> Hi Bo,
> On Mon, 20. Jul 2015 at 13:35:12 +0200, Bo Victor Thomsen wrote:
>> I don't understand the risque of regression - It would be an addition to the
>> method that reads the option values from either the registry or the ini file.
> I'm just talking about the default installation.  That would either point to a
> fresh config directory referencing the version number (which would appear to
> have lost the existing configuration) or use existing settings (pointing to
> potentially wrong directories and maybe incompatible settings).
> Both of which have their pros and cons.
> Jürgen
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150720/0961bee0/attachment.html>
