[Qgis-user] Fwd: NTv2 plugin not visible
Zoran Janković zoran.jankovic at geokt.hr
Mon Jul 20 13:54:47 PDT 2015
No, Processing plugin was an upgrade, and I've tried reinstalling it
as well. NTv2 plugin was a new install, and reinstall (multiple
times). Where is NTv2 plugin positioned in Processing Toolbox anyway,
when it does appear?
All other plugins work fine, I do not really use that many of them.
Thanks,
________________________________________________________________________
Zoran
On Sun, Jul 19, 2015 at 3:43 PM, Nicolas Cadieux
<nicolas.cadieux at archeotec.ca> wrote:
> OK,
> Not sure what to do... both where upgrades? Have you tried reinstalling just
> the NTv2 plugin? The NTv2 datum plugin is for the processing toolbox so I
> may be that it needs reinstalling. Did you loose other plugins during the
> upgrade?
> https://plugins.qgis.org/plugins/ntv2_transformations/
> Nicolas Cadieux M.Sc.
> Les Entreprises Archéotec inc.
> 8548, rue Saint-Denis Montréal H2P 2H2
> Téléphone: 514.381.5112  Fax: 514.381.4995
> www.archeotec.ca
> On Jul 19, 2015 09:16, "Zoran Janković [via OSGeo.org] " <[hidden email]>
> wrote:
> Hmmm, I did that - no effect. I can see the processing toolbox, just
> no NTv2... The same thing happens on a second computer as well -
> similar configuration (Win 8.1, 64 bit, QGIS 2.10...)
> Zoran
> On Sat, Jul 18, 2015 at 5:19 PM, Nicolas Cadieux
> <<a
> href="/user/SendEmail.jtp?type=node&node=5216149&i=0">[hidden
> email]> wrote:
>> Hi,
>> I am not on 2.10 yet and i am far from a windows box but If the plugin is
>> unavailable try reinstalling the processing plugin.  In the past, the
>> upgrade of QGIS can sometimes miss the processing plugin update especially
>> when done from an other user (like admin) under Windows.
>> www.archeotec.ca
>> On Jul 18, 2015 10:56, "Zoran Janković [via OSGeo.org] " <[hidden email]>
>> wrote:
>> Hi all,
>> I was trying to use NTv2 plugin on QGIS 2.10, Windows 8.1, 64-bit.
>> Plugin installs just fine, no errors, but it is not accessible in
>> Processing Toolbox - not there at all. Is it hiding somewhere? Or am I
>> getting blind, as well as stupid, over the years... :-) Search doesn't
>> find it.
>> QGIS is installed through OSGEO4W, otherwise working perfectly...
>> I've tried with 2.11, same result, no NTv2 plugin...
>> Any help would be greatly appreciated!
>> BR,
>> Zoran
>> Qgis-user mailing list
>> <a
>> href="/user/SendEmail.jtp?type=node&node=5216112&i=0">[hidden
>> email]
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> If you reply to this email, your message will be added to the discussion
>> below:
>> http://osgeo-org.1560.x6.nabble.com/NTv2-plugin-not-visible-tp5216112.html
>> To start a new topic under Quantum GIS - User, email
>> <a
>> href="/user/SendEmail.jtp?type=node&node=5216149&i=1">[hidden
>> email]
>> To unsubscribe from Quantum GIS - User, <a
>> href="<a
>> href="http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==">http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==">click
>> here.
>> <a
>> href="<a
>> href="http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml">http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml"
>> style="font:9px serif">NAML
>> View this message in context: Re: NTv2 plugin not visible
>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> <a
>> href="/user/SendEmail.jtp?type=node&node=5216149&i=2">[hidden
>> email]
> <a
> href="/user/SendEmail.jtp?type=node&node=5216149&i=3">[hidden
> email]
> below:
> http://osgeo-org.1560.x6.nabble.com/NTv2-plugin-not-visible-tp5216112p5216149.html
> ml-node+s1560n4125267h38 at n6.nabble.com
> href="http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==">click
> here.
> <a
> View this message in context: Re: Fwd: NTv2 plugin not visible
