[Qgis-user] Fwd: NTv2 plugin not visible
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Mon Jul 20 20:05:39 PDT 2015
I cannot help at this point, I am far from a computer (about 1000km in fact).  I would contact the plugin creator.  Have you tried the search bar in the processing toolbox? If it's installed, it should show up there.
Good luck!
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
www.archeotec.ca
On Jul 20, 2015 16:50, "Zoran Janković [via OSGeo.org]	" <ml-node+s1560n5216307h78 at n6.nabble.com> wrote:
	No, Processing plugin was an upgrade, and I've tried reinstalling it
as well. NTv2 plugin was a new install, and reinstall (multiple
times). Where is NTv2 plugin positioned in Processing Toolbox anyway,
when it does appear?
All other plugins work fine, I do not really use that many of them.
Thanks,
________________________________________________________________________
Zoran
On Sun, Jul 19, 2015 at 3:43 PM, Nicolas Cadieux
< [hidden email] > wrote:
> OK,
> Not sure what to do... both where upgrades? Have you tried reinstalling just
> the NTv2 plugin? The NTv2 datum plugin is for the processing toolbox so I
> may be that it needs reinstalling. Did you loose other plugins during the
> upgrade?
> https://plugins.qgis.org/plugins/ntv2_transformations/ >
> www.archeotec.ca
> On Jul 19, 2015 09:16, "Zoran Janković [via OSGeo.org] " <[hidden email]>
> wrote:
> Hmmm, I did that - no effect. I can see the processing toolbox, just
> no NTv2... The same thing happens on a second computer as well -
> similar configuration (Win 8.1, 64 bit, QGIS 2.10...)
> Zoran
> On Sat, Jul 18, 2015 at 5:19 PM, Nicolas Cadieux
> <<a
> href="/user/SendEmail.jtp?type&#61;node&amp;node&#61;5216149&amp;i&#61;0">[hidden
> email]> wrote:
>> Hi,
>> I am not on 2.10 yet and i am far from a windows box but If the plugin is
>> unavailable try reinstalling the processing plugin.  In the past, the
>> upgrade of QGIS can sometimes miss the processing plugin update especially
>> when done from an other user (like admin) under Windows.
>> www.archeotec.ca
>> On Jul 18, 2015 10:56, "Zoran Janković [via OSGeo.org] " <[hidden email]>
>> wrote:
>> Hi all,
>> I was trying to use NTv2 plugin on QGIS 2.10, Windows 8.1, 64-bit.
>> Plugin installs just fine, no errors, but it is not accessible in
>> Processing Toolbox - not there at all. Is it hiding somewhere? Or am I
>> getting blind, as well as stupid, over the years... :-) Search doesn't
>> find it.
>> QGIS is installed through OSGEO4W, otherwise working perfectly...
>> I've tried with 2.11, same result, no NTv2 plugin...
>> Any help would be greatly appreciated!
>> BR,
>> Zoran
>> Qgis-user mailing list
>> <a
>> href="/user/SendEmail.jtp?type&#61;node&amp;node&#61;5216112&amp;i&#61;0">[hidden
>> email]
>> http://lists.osgeo.org/mailman/listinfo/qgis-user >>
>> If you reply to this email, your message will be added to the discussion
>> below:
>> http://osgeo-org.1560.x6.nabble.com/NTv2-plugin-not-visible-tp5216112.html >> To start a new topic under Quantum GIS - User, email
>> <a
>> href="/user/SendEmail.jtp?type&#61;node&amp;node&#61;5216149&amp;i&#61;1">[hidden
>> email]
>> To unsubscribe from Quantum GIS - User, <a
>> href="<a
>> href="<a href="http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro&#61;unsubscribe_by_code&amp;node&#61;4125267&amp;code&#61;bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg&#61;&#61;">http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro&#61;unsubscribe_by_code&amp;node&#61;4125267&amp;code&#61;bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg&#61;&#61;"><a href="http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro&#61;unsubscribe_by_code&amp;node&#61;4125267&amp;code&#61;bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg&#61;&#61;">http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro&#61;unsubscribe_by_code&amp;node&#61;4125267&amp;code&#61;bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg&#61;&#61;">click
>> here.
>> <a
>> href="<a
>> href="<a href="http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro&#61;macro_viewer&amp;id&#61;instant_html%21nabble%3Aemail.naml&amp;base&#61;nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&amp;breadcrumbs&#61;notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml">http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro&#61;macro_viewer&amp;id&#61;instant_html%21nabble%3Aemail.naml&amp;base&#61;nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&amp;breadcrumbs&#61;notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml"><a href="http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro&#61;macro_viewer&amp;id&#61;instant_html%21nabble%3Aemail.naml&amp;base&#61;nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&amp;breadcrumbs&#61;notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml">http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro&#61;macro_viewer&amp;id&#61;instant_html%21nabble%3Aemail.naml&amp;base&#61;nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&amp;breadcrumbs&#61;notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml"
>> style="font:9px serif">NAML
>> View this message in context: Re: NTv2 plugin not visible
>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> <a
>> href="/user/SendEmail.jtp?type&#61;node&amp;node&#61;5216149&amp;i&#61;2">[hidden
>> email]
>> http://lists.osgeo.org/mailman/listinfo/qgis-user > _______________________________________________
> <a
> href="/user/SendEmail.jtp?type&#61;node&amp;node&#61;5216149&amp;i&#61;3">[hidden
> email]
> below:
> http://osgeo-org.1560.x6.nabble.com/NTv2-plugin-not-visible-tp5216112p5216149.html > To start a new topic under Quantum GIS - User, email
> [hidden email]
> href="<a href="http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro&#61;unsubscribe_by_code&amp;node&#61;4125267&amp;code&#61;bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg&#61;&#61;">http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro&#61;unsubscribe_by_code&amp;node&#61;4125267&amp;code&#61;bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg&#61;&#61;">click
> here.
> <a
> View this message in context: Re: Fwd: NTv2 plugin not visible
> [hidden email]
> http://lists.osgeo.org/mailman/listinfo/qgis-user _______________________________________________
[hidden email]
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/NTv2-plugin-not-visible-tp5216112p5216307.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/NTv2-plugin-not-visible-tp5216112p5216313.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150720/09cb6437/attachment.html>
