[Qgis-user] Processing Update: GRASS not working in the toolbox
Filipe Dias filipesdias at gmail.com
Tue Jul 21 02:56:36 PDT 2015
There is a bug filled on that issue. This issue come up a few times over
the past week.
http://hub.qgis.org/issues/13072
Cheers
On Tue, Jul 21, 2015 at 10:38 AM, Bernd Vogelgesang <
bernd.vogelgesang at gmx.de> wrote:
> Hi,
> am I really the only one with issues with processing.
> I already thought that I solved the problem. On my machine at home, I
> checked the repositories, reinstalled everything, updated Processing and
> ... surprise surprise .. everything worked fine, even after restarting QGIS
> several times.
> But today when I wanted to resume with the project: Missing dependency.
> This algorithm cannot be run :-(
> How is that possible???
> What can I do to check the circumstances? The provided link doesn't help a
> lot
> http://docs.qgis.org/testing/en/docs/user_manual/processing/3rdParty.html
> Cheers
> Bernd
> Am 20.07.2015, 18:32 Uhr, schrieb Bernd Vogelgesang <
> bernd.vogelgesang at gmx.de>:
>  Hi,
>> I'm going nuts! It took me weeks till a got a working QGIS 2.8 install
>> with GRASS(7) working in the toolbox on Linux Mint/Ubuntu.
>> Using the model builder to create some workflow, I became aware that
>> there is a Processing update available.
>> Doing this update, the model doesn't work anymore, cause GRASS stopped
>> working in the toolbox.
>> When I do a fresh install without updating Processing, I get an error
>> when I try loading my model (which I unfortunately saved with the new
>> Processing version).
>> Ok, I could create that model again with the non-updated Processing
>> version, so the GRASS function I need is available, but I also rely on the
>> new "OGR Dissolve Polygons" function introduced with the new Processing
>> version, cause I need to sum up an attribute while dissolving, and there is
>> no alternative function at hand.
>> Anyone an idea what to do? Seems I'm caught in kind of a time/version
>> hole.
>> Cheers
>> Bernd
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Bernd Vogelgesang
> Siedlerstraße 2
> 91083 Baiersdorf/Igelsdorf
> Tel: 09133-825374
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150721/dc6fe77f/attachment.html>
