[Qgis-user] Processing Update: GRASS not working in the toolbox
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Wed Jul 22 07:00:27 PDT 2015
A pity,
but is there ANY version at the moment with working GRASS in the toolbox
under Ubuntu/Mint?
Just installed the dev-version from the ubuntugis nightly repository. Same
game here. GRASS not working
Cheers
Bernd
Am 21.07.2015, 11:56 Uhr, schrieb Filipe Dias <filipesdias at gmail.com>:
> Hi,
> There is a bug filled on that issue. This issue come up a few times over
> the past week.
> http://hub.qgis.org/issues/13072
> Cheers
> On Tue, Jul 21, 2015 at 10:38 AM, Bernd Vogelgesang
> <bernd.vogelgesang at gmx.de> wrote:
>> Hi,
>> am I really the only one with issues with processing.
>> I already thought that I solved the problem. On my machine at home, I
>> checked the repositories, reinstalled everything, updated >>Processing
>> and ... surprise surprise .. everything worked fine, even after
>> restarting QGIS several times.
>> But today when I wanted to resume with the project: Missing dependency.
>> This algorithm cannot be run :-(
>> How is that possible???
>> What can I do to check the circumstances? The provided link doesn't
>> help a lot
>> http://docs.qgis.org/testing/en/docs/user_manual/>>processing/3rdParty.html
>> Cheers
>> Bernd
>> Am 20.07.2015, 18:32 Uhr, schrieb Bernd Vogelgesang
>> <bernd.vogelgesang at gmx.de>:
>>> Hi,
>>> I'm going nuts! It took me weeks till a got a working QGIS 2.8 install
>>> with GRASS(7) working in the toolbox on Linux Mint/>>>Ubuntu.
>>> Using the model builder to create some workflow, I became aware that
>>> there is a Processing update available.
>>> Doing this update, the model doesn't work anymore, cause GRASS stopped
>>> working in the toolbox.
>>> When I do a fresh install without updating Processing, I get an error
>>> when I try loading my model (which I unfortunately saved >>>with the
>>> new Processing version).
>>> Ok, I could create that model again with the non-updated Processing
>>> version, so the GRASS function I need is available, but I >>>also rely
>>> on the new "OGR Dissolve Polygons" function introduced with the new
>>> Processing version, cause I need to sum up an >>>attribute while
>>> dissolving, and there is no alternative function at hand.
>>> Anyone an idea what to do? Seems I'm caught in kind of a time/version
>>> hole.
>>> Cheers
>>> Bernd
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Bernd Vogelgesang
>> Siedlerstraße 2
>> 91083 Baiersdorf/Igelsdorf
>> Tel: 09133-825374
Bernd Vogelgesang
Siedlerstraße 2
Tel: 09133-825374
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150722/b2b7e9fe/attachment.html>
