[Qgis-user] map frame questions
Neumann, Andreas
a.neumann at carto.net
Thu Jul 23 01:47:55 PDT 2015
It would be better to use just a basic rectangle instead of an HTML
frame with no content. There are basic shapes available, like
rectangles, circles/ellipse and triangles. The icon for the basic shapes
is next to the icon you use to add scalebars. You can lock the rectangle
element after creation so it doesn't interfere with the selection of
other elements.
Andreas
On 2015-07-23 10:36, Ujaval wrote:
> For outer black border, you can add a new HTML frame with no content. It's a hack, but seems to work.
> Geographic coordinates without seconds is possible. Use format 'Degree, Minute' and change coordinate precision to 0.
> On Tue, Jul 21, 2015 at 4:43 PM, Luca Galuppini <luca.galuppini at gmail.com> wrote:
>> dear all i am working on a map border, i would like to obtain a result similar to this one:
>> http://www.giroparchi.it/it/cartadeisentieri/ [1] only, i cannot find in the map composer the possibility to: - add an outer black border 7-10 mm away from the actual map frame - represent UTM coordinate values in thousands meters (ie 587 instead of 587000)
>> - represent geographic coordinates without seconds (ie 44°15' instead of 44°15'0") is there a way to do it ?
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user [2]
Links:
[1] http://www.giroparchi.it/it/cartadeisentieri/
[2] http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150723/0dd22140/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150723/0dd22140/attachment.png>
